DME speed / Ref sensor code
I disconnected the three connectors on the engine assuming they were keyed and / or different sizes ... two of them are identical. The two I'm having trouble with I think go to the variable reluctance sensors on the back of the engine.
The wires have barely readable tags on them, the plug side I think says BC, BG and the receptacle side DC ,DG. Should I try DG to BG? The C is hard to distinguish from a G! How about a german lesson? What do those initials stand for? |
If the car doesn't start, you know they have to be swapped ..... ask me how I know.
:D It won't hurt anything if they're wrong. |
Josh is correct. Doesn't hurt a thing if they're connected wrong. Just won't start.
The way I remember which is which is BG = Bottom. The DG is the middle one, the head temp sensor is the top white connector.
-Chris |
Re: DME speed / Ref sensor code
Don't know what the actual letters stand for...:( Ralph |
DG for Drehzahl-Geber (revolutions giver)- Speed Generator
BG for Bezugsmarken-Geber (reference mark giver) - Ref Mark Generator |
| All times are GMT -8. The time now is 04:55 AM. |
