Wer bremst verliert
JohnJL's Avatar
JE Pistons finishing
Thought I'd share my observations on my 9.5CR 95mm 3.0 JE Pistons.
I noticed that on all of the cylinders, there were residual drilling scraps clinging to the oil ring holes. THese came away fairly easily with a tweezer or with a kimwipe. These scraps would each be big enough to clog a squirter, spray bar hole, or ruin a bearing.
I also found each wrist pin oil channel had one side partially blocked with aluminum pushed over in the drilling process. I used a dremel with a dentist bit to smooth this out in each side. Of the two channels on each side of the piston, one was always cleanly drilled and the other always had a little residual metal. Must be due to the rotational direction of the drill. I opened them up in order to avoid starving of one side of the wrist pins.
Here is a pic of where I smoothed out. I'm pointing to the rough side of one of the passages to show where I'm talking about.
Hope it helps someone.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 09-03-2005, 07:53 PM
Irrationally exuberant
ChrisBennet's Avatar
Thanks for the tip. Be sure to CC your motor. I received 2 set of the "9.5:1" 98mm JE's and they CC'd out to 10.5:1.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-03-2005, 07:57 PM
Wer bremst verliert
JohnJL's Avatar
Hi Chris,
THanks, I will. I guess if they do test that high I'll have to go dual plug ;-)
Old 09-03-2005, 08:06 PM
