wahoofan's Avatar
timing settings on 2.4
Just checked timing on my 2.4 mfi and I'm at 3 ATDC at 900rpm, 30 BTDC at 6000rpm w/vacuum line connected, 38 BTDC at 6000rpm w/vacuum line off and plugged. Are these values close enough, or am I getting too much advance? BTW, car seems to run great like it is.
wahoofan
'72 911T Targa
Old 09-05-2005, 01:14 PM
buster73's Avatar
You are in the ballpark.
Stock specs would be 4-6 degrees ATDC @ 900 rpm and 31-38 degrees BTDC @ 6,000 rpm (with vacuum line disconnected). Timing should never exceed 38 degree BTDC with vacuum line disconnected.
Regards,
Guenter
73.5 911T, mod
Old 09-05-2005, 06:03 PM
wahoofan's Avatar
Should I be worried that my advance is already at the upper limit (38 BTDC) when freshly tuned? Does advance change as points, plugs, etc. wear?
wahoofan
'72 911T Targa
Old 09-06-2005, 03:46 AM
jluetjen's Avatar
Does your car still have points? Is the dwell set correctly?
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 09-06-2005, 04:29 AM
wahoofan's Avatar
Yes & yes
wahoofan
'72 911T Targa
Old 09-06-2005, 06:17 AM
wahoofan's Avatar
Car doesn't seem to run as well today and idle is down to about 800. Could this be a result of new points "breaking themselves in"? Any thoughts about my timing being at 38BTDC?
wahoofan
'72 911T Targa
Old 09-06-2005, 12:12 PM
buster73's Avatar
If the engine is otherwise sound and you use a good fuel quality 38 degree BTDC is no problem. Of course you can reduce some degrees if you feel uncomfortable and don't need max power. New points certainly can settle and you should keep an eye on dwell angle and timing.
I would always recommend a Pertronix Ignitor (or similar system). Avoids the hassle to change and adjust the points and (with the prize of points these days) pays off quite fast. However - being a mechanical engineer- I always have an set of points with me, in case some electronic component decides to go bust (many posts on this issue on this forum).
Regards,
Guenter
73.5 911T, mod
Old 09-06-2005, 12:44 PM
jluetjen's Avatar
I agree, get a "pointsless" system such as the Crane Fireball 700 that I have in my car and you'll never have to worry about points wear or setting the points ever again. I haven't touched mine in the 3 or 4 years that I've had my car.
John
'69 911E
Old 09-06-2005, 01:12 PM
