GFCC
I need a little front suspension help please.
I am trying to lower the front of the 76 and the adjustment bolt is all the way out. I was wondering, to get more travel out of the front adjuster do I need to remove the bolt completely and pull the torsion bar end cap/ adjuster off, jack up the hub a bit and put the end cap back on a different set of splines (reindexing if you will)?
Does the end cap/ adjuster just pry/ pull off? Thanks.
Jeff 1976 911 Coupe w/ Euro 3.0 - Sold 1987 Carrera Coupe - Sold 1999 Carrera Cabriolet - Current |
Friend of Warren
Sounds like you have it figured out. Not hard to do. Maybe 5 minutes.
Kurt V No more Porsches, but a revolving number of motorcycles. |
GFCC
Cool, Thanks Kurt.
