Me like track days
Craig 930 RS's Avatar
Question Castrol SRF mix?
Can you mix Castrol SRF with other fluids such as Motul?
(Ignoring the fact that mixing an $80 fluid with a $13 fluid isn't that intelligent......)
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 09-07-2005, 07:16 PM
KobaltBlau's Avatar
no, it will explode.
In all seriousness, base chemicals are different, so I don't think it's a great idea. why would you want to? just buy some more SRF if that's what is in there. My guess is you have a track day this weekend and you're low on fluid, and you can't find SRF locally. hmm.
I think your best options if this is true and you are truly low are to find some SRF or flush the whole system with DOT 4 and bleed.
Andy
Old 09-08-2005, 11:20 AM
Me like track days
Not my car - it is a customers' who bought his 996 TT with SRF in the system. He rightly believes that SRF for his street use application is complete overkill - I advised him to do a complete flush with Motul.
SRF is needed only in circumstances where all else has been done to alleviate brake cooling issues and one still gets fluid boiling or a significantly soft pedal.
I can't get an absolutely straight answer from Castrol, but I did get this:
"Mixes with conventional polyglycol fluids."
http://www.castrol.com/castrol/productdetailmin.do?categoryId=82915521&contentId=7001576
http://www.castrol.com/castrol/productdetailmin.do?categoryId=8290039&contentId=6007734
Old 09-08-2005, 11:34 AM
Bill Verburg's Avatar
All of the Dot, 3.4, and 5.1 can be mixed. You do get greatly reduced performance
Bill Verburg
Old 09-08-2005, 01:17 PM
