Uncle Enzo's Avatar
How is this vent tube attached to the carb?
I was cleaning my filters last night and noticed this bowl vent tube was loose. Its not going anywhere but does have wiggle room. Ive looked at the parts diagram and cant see how its attached. I am thinking its just a pressure fit. Id rather leave well-enough alone if I can. Carbs are Weber 40s
1976 911S
MidYear Fever is alive and well.
Old 10-14-2015, 09:29 AM
1QuickS's Avatar
The end has a reduced diameter that passes through the top cover. It is retained by upsetting the end (riveted).
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 10-14-2015, 10:05 AM
KTL KTL is online now
Schleprock
KTL's Avatar
I believe they are either flared underneath the carb top covers, or there's a C-clip holding it in place. I recall my former Weber 46 had vent tubes that were a little bit wobbly and they were fine. Best to not worry about it.
Kevin L
'86 Carrera "Larry"
Old 10-14-2015, 10:06 AM
Uncle Enzo's Avatar
Thanks, Fellas!
1976 911S
Old 10-14-2015, 10:07 AM
1QuickS's Avatar
Vent pipes work loose due to torsional vibrations of the engine. They can be tightened by using an arbor press and a flared tool to re-set the riveted end or you can buy a replacement vent pipe kit from me.
Many times the inside end of the pipe is rusty and drops flakes of rust into the float bowl. These later end up on the tip of your idle jet.
Paul Abbott
Old 10-14-2015, 10:49 AM
Uncle Enzo's Avatar
I was hoping you would weigh in on the situation, Paul!
1976 911S
Old 10-14-2015, 11:20 AM
