First DE advice needed
I'm attending my first DE at Blackhawk this Thursday and Friday. I'm wondering what one should bring along to the event other than the obvious helmet.
Also, I'm wondering about car preparation. I'm not sure how old the brake fluid is. I have had the car for about a year and it's very well maintained, but is this somthing one need be concerned about for their first DE? Any help/information/advice would be greatly appreciated.SmileWavy |
I have a draft of a paper on “How to go to events.” E-mail me your e-mail address and I will send you a copy. It is a 240K MS Word.doc, too large for the Pelican.
Best, Grady gradyclay@hotmail.com I don’t use PM. |
Definitely flush the brakes. Put some more aggressive brake pads in there. The stock pads will be toasted before the day is done. For you first DE, I think Ferodo 2500's will be fine.
How old is your oil? Make sure to take everything out of the car that isn't attached. Ray ("Ray 911s") who happens to have a black 1977 2.7 will be at that DE. His boss may be bringing a Carrera GT....better get out of the way :D |
If I can get some 2500 by Thurdays, I can send them up with Ray for you. You'll just have to swap them out between sessions. Let me know. (Ray's coming by the house Thursday)
Here is the "what to bring" list from the Rocky Mountain Region PCA website: http://www.rmrporscheclub.com/staticpages/eventregnew.aspx
What do you have to bring? * directions to the track, check the web page for these * helmet, don't forget it * hat, for protection from the sun * sunglasses * sun screen, Colorado sun can be very intense * white or light colored long sleeve cotton shirt for driving and working corners * long cotton pants (blue jeans ok) for driving and working corners * cooler with ice, plenty of drinks and lunch or snacks. At some events there may be food concessions at the track or nearby - check the description of the event in the news letter or the web page * a small folding chair * stop watch (to see how well your friends are doing) * paper towels and window cleaner * tire air pressure gauge, a better one has an actual gage and not just a sliding rule * wrench to tighten wheel lug nuts, preferably a torque wrench * your car tool kit, jack, etc. * cotton towels * shop rags * gasoline, be sure you have enough to complete the event. Some people don't like to carry the extra weight of a lot of gas but be sure you have enough so you don't run out. A half tank is usually not enough. * a couple of quarts of oil * air pump or an air tank (be sure you fill it) * something to hold all this stuff, a plastic container with a snap on top is good for this. You can leave all of your track stuff in it, always have it handy and not have to worry about forgetting something. You may also use this for things you must remove from your car during the event (see top-tech notes above). |
If you haven't done it already, use a brake fluid with a higher boiling point...ATE Super Blue is what I use, but there are similar fluids of the same caliber out there.
Also, "nut & bolt" the car. Get it on a hoist (or jack with jack stands) & check every nut and bolt you see for tightness. No need to gorilla-tighten everything, just make sure nothing is loose! Grady's list goes into great detail about things to do & bring to the track (alot of thinking went into his document!). Learn alot, and HAVE FUN!! |
Grady - I'd be more than happy to host the ,doc file on my web server space, so you wouldn't have to keep emailing it out, you'd just send a link. Send it to me at work thom.fitzpatrick@hp.com
Here's my "Track Day Checklist":
Track Day Checklist __ Car __Engine __ visual inspection / check for leaks __ check oil & brake fluid levels __Brakes __ inspect pads and rotors __ inspect brake lines __ bleed or flush brake fluid __ check for firm pedal __Tires / Suspension __ inspect wheels for damage __ inspect tires for wear and damage __ check torque on all lug nuts: 95 ft-lbs. __ check tire pressure __ inspect suspension fasteners for tightness __Seats __ check seat bolts __ check seatbelts / mounting areas __General __ check all lights __ wash the car / clean the windows __ remove boom box / tape wire ends __Safety Gear / Clothes __ helmet / gloves / driving shoes / long sleeve shirt / extra socks __ sun block, sun glasses, and hats __Tools / Supplies __ torque wrench and ¾” deep / extension __ tool box / zip ties __ jack and jack stands __ tire pressure gauge __ pyrometer / stopwatch __ window cleaner / paper towels __ duct tape / blue masking tape __ mechanic’s gloves / knee pads / latex gloves __ 2 quarts of 15/50 Mobil 1 oil __ 2 pints Ate Super Blue brake fluid / Power bleeder / catch bottle / brake cleaner __ Pagid orange brake pads __ car sunshade __Snacks / Supplies __ drinking water / Gatorade / Ice in ziplocks __ snacks: protein bars, oreos, peanut butter sandwiches __ chair __Camera Equipment __ video camera / extra charged battery __ microphone / wind sock __ digital camera / long and short lenses / extra charged battery Hope this helps a little. ;) |
Here is an Adobe guide (37 pgs!) that is pretty encompassing.
http://www.metronypca.org/DriverEd/DE%20Guide/Metro%20NY%20DE%20Guide%201_4g.pdf |
Ahhhhh!! So much for my idea of just showing up with my helmet and driving! Too......much.....small brain......overload.....:)
Thanks everyone for the great info. It's clear that I am woefully unprepared for this. I'll try to get it together and do my best. Souk-thanks for the offer. SmileWavy However, a friend is bringing over a set to help me out tonight. |
No problem. Have fun!
His pads are stock! Can I still get the 2500s from you? |
Done!
We'll have a set ready to give to Ray. Have Fun!! |
I just finished my first DE event at Mosport yesterday.
I found it a lot more stressful getting my car ready and everything packed and accounted for than I did going through the 'double apex off camber turn two' of mosport! The lists above are pretty thorough. Don't know if I saw it but a tarp is pretty handy to put all your stuff on, or if it rains. Good luck, you'll love it. -Rob PS. Thanks to our fellow pelican member TonytheTarga who I met when I pulled in Saturday morning (Tony is an instructor). He really helped me a lot and showed me what these cars can do!!! |
Pads? For a DE? nah, i just took some tools, my helmet, sunscreen and a chair.
granted I knew VIR had food and beverages... i hate being prepared :) Britt |
Hey Rob,
Glad you had fun and gave that car some exercise. I am sure you'll be back there and after you get Mosport down pat, you'll need to venture to Watkins Glen to experience another historic awesome track. See you next year. |
Well thanks again for the advice. I packed tools, chair, canopy, cooler, brake fluid, oil, more tools, helmet, hat, glasses, etc.
I swapped brake fluid just now using a Motiv brake bleeder from our wonderful sponsor.:) I had it sent out next day air along with some ATE Super Blue. What a pleasure it was to use the bleeder and have bleeder nipples that loosen freely. It took hardly any time at all. I'll be off to the races, as it were, at 4 am tomorrow. Wish me luck. <a href="http://imageshack.us"><img src="http://img152.imageshack.us/img152/1474/dsc001130ey.jpg" border="0" width="680" alt="Image Hosted by ImageShack.us" /></a> |
Have not seen this recommendation yet but bring a cooler of beer to make friends with after the first night. Hanging out drinking a few cool ones after the driving is done and bs'ing with the guys is a great opportunity to learn and wind down. Over time you will meet guys that will be able to help you with broken down parts, brake pads, and just about anything else you could need to keep your car on the track and help you get home if needed.
| All times are GMT -8. The time now is 05:26 PM. |
