No one tells you this part… (longhood latch panel install- help!)
Hi everyone!
So there are plenty of threads with information on removing a shorthood latch panel, but none that tell you how to get the new longhood one in. I feel a bit dumb for asking, as the process should be obvious, but someone here undoubtedly has the answer. (No, installation is not the reverse of removal…) It wasn’t that hard to remove the old one, just time consuming grunt work, but that went fine and everything cleaned up well. I have the following observations: -I considered if the panel could slip downward into place from inside the frunk, but there are several reasons this won’t work. The big one being that it isn’t possible to slip the bottom of the new panel over the outside of the suspension pan, which has to happen. The battery to chassis grounding post also appears to be in the way. -It is also impossible to insert the panel from the outside, as anyone who has done this will know. What am I missing here? Some pics. All cleaned up and ready for the new panel: ![]() Its not going in this way as far as I can tell:
1981 911SC restomod "Minerva" 2004 Boxster S 2021 Cayman GTS 4.0 manual "Olive" 2014 Cayenne GTS V8 (wife's lover) The slope is not slippery; in fact it is entirely frictionless. |
Might need to straighten out the lips one side and bend it back once the panel is in. I always did it along with the suspension pan, never tried it by itself. Good luck.
It’s easiest to open up the ends like John said, if I remember correctly you need to notch the top ends ( Channel) so they fit underneath the inner fenders. Also have to cut or drill spot welds so the bottom corners of the new panel slides in. If I remember correctly getting the bottom of the new panel in correctly is the painful part.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
(man/dude)
Other than doing a full pan replacement the suggestions thus far are good.
A small cut at the top and bottom of the fender liner and basically splay the inner fenders outward far enough to slip the panel in should/could/might, hopefully, do it. Or, go all in... ![]()
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Thanks everyone!
I thought it might require some additional surgery, but needed to hear it from those who have been there before I start cutting. I did consider opening up one end, as that will be easy, so that's what I'm going to do. Quote:
In your case ALL OUT... as in cut it all out and rebuild the car! ![]() Pan is OK, so I'll go for a little nip and tuck instead. Thanks for the pics and info! I've studied the first couple pages of your build thread backwards and forwards, so those pics are very familiar! .
(man/dude)
Now - speaking of test fitting the panel, I can't recall how much of the new sheet metal you have on hand, but don't succumb to the temptation to weld in that new panel without test fitting it with your hood, and the bumper seal, and the bumper, and the fenders. And the turn signals and the horn grilles. This is the critical point in the project where the fit (or lack thereof) of all these components is determined. Yes, there is a certain amount of adjustability with everything but the one thing that can't be moved once installed is that damn channel that holds the bumper seal. And it basically needs to be within a few mm of the correct position or else there will be gaps and misalignment of the bumper seal. ![]() The hood and fenders need to be positioned with respect to the cowl and doors, and each other, so imagine if you get those perfectly aligned with all the gaps where you want them, and you've already committed to a position of that bumper seal. It's not just the vertical position that's important, it's the fore/aft position. Everybody struggles with this, even the factory restoration department. Even Singer doesn't nail it on every car.
I've test fit my new fenders, and they are really not great so I will have some serious work to do there to get the gaps right. I'll surely be needing advice!
Full Send Society
Can’t stress Jonny’s point about fitting enough. Clamps, tape, clekos, screws… use whatever you need to get the whole thing put together and fit to your liking before securing anything. Even perfectly fit parts have a way of shifting, distorting and otherwise conspiring against you later on.
It’s kinda like home building: if you want the tile to look good start with the framing.
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
On positive note, and to follow up the original purpose of this thread, I did a little metal surgery and the latch panel went in with no drama. Screwed temporarily in place until I fit the rest. There are probably multiple ways to do the same thing but here was my solution: ![]() ![]()
I’d love some advice on the fenders, “while we’re in there.” I bolted up the left fender with 5 bolts in it including the one in the cowl closest to the door, and as most people find out the hard way, a repro panel just isn’t going to match a hand-built car very well. I can probably massage the fender to cowl area to sit better somehow (haven’t ever done it, so I’ll need some help!) Gaps I can weld up or shape. Its at the front of the fender I’m most concerned— the flange on the outer fender that mounts to the inner fender deviates greatly in it’s contour at the very front, and the fender sticks out past the latch panel. Having never worked on a longhood or conversion like this, it is hard for me to know what is correct, or can be corrected, or is just plain wrong. I’m seriously considering welding light boxes to my shorthood fenders instead, but that won’t be a piece of cake either.
Here you see the difference in these contours where the fenders meet: ![]() ![]() And the rest of the poor fit: ![]() ![]() ![]() ![]() ![]() ![]()
(man/dude)
You have a pm
Full Send Society
The fit of the front fenders was the number one reason I decided to keep my car’s original fenders and weld in the light boxes. I figured that even if the extensions were crummy and didn’t fit well (they were and they didn’t) it would be less work than shaping a whole fender.
Ultimately, no matter which way you go there will be shaping involved. It just might be easier to keep the work isolated to the light box area rather than fighting the whole fender.
Thanks, replied.
The 9 Store
Porsche sourced fenders are much better than Dansk. We get them at a discount from our local Porsche dealer ( Delaware Porsche Parts dot com) no sales tax in DE and pickup saves a ton on shipping. If you are within a couple hours, it’s worth the drive. It’s the dealer in Newark Delaware but you have to order through the online site.
All used parts sold as is. |
I wonder if I can put a couple fenders in my checked baggage? 😁 Those days must be long gone-- sourcing light boxes in Europe, I'll be out over a grand after shipping and tax. The fenders are like new so I can sell them. Or cut out the light boxes as the rest of them is crap!
