-   -   option on these headers (http://forums.pelicanparts.com/porsche-911-technical-forum/241310-option-these-headers.html)
Tex3 09-16-2005 03:01 PM
opinion on these headers
Anyone know if these would fit my 81sc 3.0 with no problems???
http://forums.pelicanparts.com/uploa...1126908040.jpg
Bill Verburg 09-16-2005 03:05 PM
Should be no problem.
Tex3 09-16-2005 03:13 PM
Say Bill,
Dont they look different than the european headers. seems like the black ones are shorter. or is it just me??
http://forums.pelicanparts.com/uploa...1126908801.jpg
http://forums.pelicanparts.com/uploa...1126908813.jpg
Bill Verburg 09-16-2005 03:27 PM
You just need different length extension pipes to get to your muffler.
The shortys are designed that way to leave room for a cone type stinger.
like this
http://forums.pelicanparts.com/uploa...1126909606.jpg
Tex3 09-16-2005 03:38 PM
anybody know where you would place the oxygen sensor? drill and tap??
DW SD 09-16-2005 03:50 PM
I'd drill a hold and then weld a bung in an appropriate spot on the header. If your stock O2 sensor is before the collector in an individual primary pipe, then weld there. If it is after the pipes merge (collector) then weld there. It should be in an analagous position.
Drilling and tapping won't work the tube wall thickness is not enough to tap.
Doug
Bill Verburg 09-16-2005 03:51 PM
just weld a bung in the collector
http://forums.pelicanparts.com/uploa...1126911063.jpg
Tex3 09-16-2005 03:53 PM
thanks Guys didn't think about the bung until yall metion it
Tex3 09-16-2005 04:54 PM
last question you think 280.00 is too much for these??
