efhughes3's Avatar
Question onn 993 caliper rebuild...
I'm rebuilding a set of calipers and the first piston's seal & dust boot aren't cooperating. The Brembo instructions say to install the seal, put the boot on the piston, and then insert in so the boot seats. I can't get the boot to seat this way.
I did find a website where the guy says to install the seals, then install the boots in the caliper bore/groove. THEN, you pull the boot over the piston (the hard part) and then insert the piston into the bore.
Based on my first result, the second method may make sense. Any input?
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 10-01-2005, 12:41 PM
