Kelly Bell's Avatar
Mixture screw - Where is it?
Does anyone have a picture of the mixture screw on my 75 2.7 CIS? I have an extra long 3 mm allen wrench and cant find it! I need a picture!
Thanks!
Kelly Bell
72 MGB
75 911S
00 Volvo S70
Old 09-20-2005, 03:55 PM
down a small hole between the fuel distributor and sensor plate boot. right in the middle, in that little gap between them. use a flashlight.
206 637 4071
Old 09-20-2005, 03:56 PM
Yellowbird RS's Avatar
Please identify the mixture screw
X/A
Old 09-20-2005, 06:11 PM
Kelly,
Once you find the mixture screw you want to know what direction to turn and how much. To lean out the mixture turn the screw left (counter clockwise).
You may want to remove the air filter and cover, then reach in and up to support the lever arm that moves up and down with the air flow.
As I described in your other post, make sure this arm moves freely.
1/8th to 1/4th turns are big.
Let us know how things go. We all like input.
Good luck and keep asking.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 09-20-2005, 06:57 PM
