450knotOffice's Avatar
Question Tire pressures for 84 Carrera
Sorry if you guys have seen this before but I can't seem to find a straight answer without wading through way too much chaff.
I've got an '84 Carrera with 205/55 16's mounted on 7's up front and 225/50 16's mounted on 8's at the back. The car originally came with those size tires and the sticker in the engine compartment advises 29 psi front and 36 psi rear.
I know that the factory was looking for a good amount of understeer to protect the poor driver from oversteer hell. However, I'd like more neutral handling.
What would the experts out there recommend for tire pressures that would give me a little less understeer? I've read from a few sources on this board that I should go with a more even split, for example 32 front and 34 rear.
The car weighs 2575 empty, has about a 40% to 60% front to rear weight bias, sits at about Euro height, has been corner balanced perfectly (to within 3 pounds front and 0 pounds rear), and has these alignment numbers: camber front - Neg 1.4 degrees, camber rear - Neg 1.25 degrees, Toe front - +15', Toe rear - +20', Caster - all the way back, I believe.
Do you have any recommendations?
Old 09-20-2005, 01:42 PM
Bill Verburg's Avatar
To decrease understear, you want the following
  • reduce weight at the front
  • more neg front camber
  • more pos rear camber
  • larger front tires
  • smaller rear tires
  • higher tire pressure in front
  • lower tire pressure inback
  • wider front track
  • larger front spoiler
  • smaller rear spoiler
  • wider wheel in front
  • narrower wheel in back
  • lower front spring rate
  • raise rear spring rate
  • smaller front swat rate
  • larger rear sway rate
  • softer front shocks
  • harder rear shocks
Some of these require $, others are freebies
Bill Verburg
Old 09-20-2005, 02:18 PM
Stay with 36 at the back and up experiment with the fronts. Try 32 for a start. I've found a 7psi difference to favour understeer.
Simon
85' Carrera 3.2
02' Mazda MX5
Old 09-20-2005, 03:06 PM
Friend of Warren
I run 32 front/36 rear
Kurt V
Old 09-20-2005, 03:09 PM
Large Registered Member
PatrickB's Avatar
Hey Scott~
You've seen how low my ride is...
I go just the opposite, and my car rarely swings it's arse out...
32 front, 29 rear!
'85 Carrera Coupe, Marble Grey #118 JP/R6
'93 Lexus SC400, '00 Ford F-150
'70 911T- 2.7 (SOLD)
Old 09-20-2005, 03:21 PM
Thanks for the numbers guys.
I checked my tire pressures just before I stepped out and found all of them way off.
LF - 27
RF - 26
LR - 29
RR - 31
When it stops raining I'll straighten that right out.
Old 09-20-2005, 03:38 PM
slodave's Avatar
I have an '84 Carrera, I try to keep the fronts at about 32-33, rears at 36. That's cold air pressure of course. I like the way it drives...
Old 09-20-2005, 04:31 PM
bigchillcar's Avatar
boy, i must have totally missed 'p-car tires 101'...i thought we just all went by what the tires say! mine say 35 max pressure cold, so that's what i've been doing all along. do i need to be running something different then on my totally street car? i run 215/60/15's on 6 inch wheels.
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 09-20-2005, 04:39 PM
PatrickB's Avatar
It's all about what you are comfortable with!
Most daily drivers really aren't able to discern between 1-2 lbs.difference. However, 5lbs, yes! F1 drivers will ***** about being a 1/4 lb change!
Just experiment on your favorite corner, or better yet, highway onramp at the same speed, but different combos!! I'm sure someone will chime in and say that's what auto-x is for, but not all of us are interested in that!
Old 09-20-2005, 04:53 PM
2008 M3
2008 Tahoe
2006 BMW X5
1985 911 F Stock - Sold
www.ladamapizzeria.com
Old 09-20-2005, 05:03 PM
On the track I run 32F 36R HOT on Kuhmo VR - 30F 35R Hot on Pirelli Corsa. For street I would run close to the same 30-32F 34-36 R. I measure hot because it will change greatly when they warm up. But as stated above do what is comfortable to you
2008 M3
2008 Tahoe
2006 BMW X5
slodave's Avatar
Another thought. My '88 VW Scirocco 16v was setup for canyons - and did a fine job too. I added a tire monitoring system. Was a good device, gave temps, pressures, alarms for various conditions... You will find that each tire will report a different temp. after running around for a while. Engines are not completely symmetrical and air temps are different around each tire. I'm pretty sure that my 911's right front tire would be hotter than the left - due to the oil cooler in the fender well. Tire pressure also affects mileage. We all are paying very high prices for that premium gas.
Dave
Old 09-20-2005, 08:47 PM
It didn't stop raining until late so I'll add some air tomorrow.
What brought all this to light was our run on Sunday in the canyons around Mulholland. On the super sharp second gear corners, my car would understeer so badly that I ended up completely in the opposite lane a couple of times with the wheel hard over. The only way to get it to tuck in would be to chop the throttle.
I'm guessing I might have gotten a little bit of tire roll due to the low pressures up front.
Old 09-20-2005, 10:35 PM
ryan
Ryan, you definitely don't want to run what the tires say. You may end up running that, but that's a max inflation, not a recommended. You'd be much better off running what the car manufacturer says.
Most people run something in the range of 32-34 cold in the front and 34-36 cold in the rear. I used to run about 2-3 lbs higher in the rear and that served me quite well.
Old 09-20-2005, 11:21 PM
Re: Tire pressures for 84 Carrera
Can you double check those alignment numbers for the camber? If those really are your numbers then you may be in for a surprise. The most common alignment specs call for .25-.5* more camber in the rear than in the front. I've seen one or two people recommend/use the same camber front and rear, but I don't think I've ever heard anyone using more in the front (unless the car has huge rear tires maybe, and even then).
A common street/track number would be -1* frt and -1.5* rear. Some go much farther if they can.
No expert, just thought it seemed unusual.
Old 09-20-2005, 11:27 PM
Carl83911's Avatar
ryan
If that is the case, then i'd have to inflate mine to 50psi
Carl,
Old 09-21-2005, 12:22 AM
