Flasher relay
A tip for those trying to replace the relay. If you pull on the plug into which the relay connects, it will pop out and you can then use two hands to plug in the new relay. Would have saved me the hours I took trying to line up the relay with the plug.
Brian
87 Black/Black 911 Coupe
Gone: 01 Rainforest Metallic Green/Savannah Beige 996TT Coupe; 90 964 C2
Old 05-12-2019, 08:57 AM
