915 Upgrades?
This morning I send checks for Geof33 half finished 82sc backdated 73 RSR project and an Instant-G 3.6 V-Ram engine and kit. The car will be be used for open track events and on the street (road trips).
The car comes with a freshly rebuilt 73 915. With advice from Steve Timmons, I will sell this tranny and look for a 915 from a SC. I don't know anything about these trannys (or trannys in general) and was wondering what I should think about as far as modifying one for my appliccation. I'm sure I'll want a lsd but don't know which one or what else - cooler, gate, etc.. What should I plan on spending for the parts and labor. Thanks- Craig Backer |
Get the heavy duty bearing retainer from either PowerHaus or Wevo, the heavy duty side plate from PowerHaus, and if you don't score a factory cooling setup (which I've heard are fragile), drill and tap the case for an external cooler.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Administrator
Before you sell the 73 box, I would put in a call to Hayden at Wevo and get his opinion on the best transaxle for your application.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Administrator
Yea, WEVO makes a whole array of parts for the 915 transmissions, including very lightweight flywheels/clutch packs, machine work inside the case, oil cooling, etc.
Give Hayden a call. -Britain
'69 912 w/ 2.3L Type-4 Turbo Engine '74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans. '80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks -- www.britainracing.com -- |
