" S- Trim " ???
I have seen "S-Trim" being described on early 911's, what exactly is "S-Trim"?
1971 Albert Blue T Targa RG 439 ES 1056 |
It's thicker, wider rubber on the front bumpers and rockers seen on '69-783 911s, The 'S' trim on the bumpers is about 1-1/4" think with thin, squared aluminum base. The base trim has rubber about 1/2" wide and the aluminum base is thick and curved. It's easy to spot from a distance, because the rocker trim is just a 'spear' instead of a full 3" deep sheathing.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Here's a link to the 911T registry with a list of T options. Some are listed as "S" options.
http://www.911t.org/options/default.htm
Steve B. 1971 T 2.2 w/Zeniths Gruppe B member 171 Mid 9 Web Site Guy |
