Slumlord
Porsche_monkey's Avatar
Dim Indicator Bulbs - Both Illuminated
This is a solution to my problem, not a question.
If you have both turn indicator bulbs illuminated together (and dimly lit) then you probably have insufficient load on your turn signal relay. One of the coils ('C') is current driven and requires sufficient load to operate.
In my case I had put 10W bulbs in the front where 21W is required. I guess a failed bulb would give the same symptoms.
Old 09-23-2005, 01:08 PM
cycling has-been
bkreigsr's Avatar
thanks pbh, all this time I thought my front turn signal assembly was not grounded properly. will pick up some 21w tonite
Old 09-23-2005, 01:35 PM
Slumlord
I was sure I wasn't alone on this.
PS - I did not figure this out myself, Dilbert had to leave his cubicle and help me out.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 09-23-2005, 01:37 PM
joepfs's Avatar
What a great sight!- I was just getting ready to post a question about this problem TODAY! Thanks for your insight!
Joe
'73 911
'86 944
Old 09-23-2005, 01:45 PM
cycling has-been
bkreigsr's Avatar
any harm in going higher than 21w?
Sylvania has some 27w super-bright 1157's listed.
thanks.
say hi to dilbert for me
Old 09-24-2005, 06:15 AM
Slumlord
I guess they'll flash more quickly, and you might melt the lense cover in the front, the bulbs are very close the cover in my car. Go ahead and try, it shuold work fine. 6 Watts per side is only 1/2 amp more.
84 Cab - sold!
Old 09-26-2005, 04:52 AM
