UTKarmann_Ghia's Avatar
Send a message via Yahoo to UTKarmann_Ghia
Question Rocker rubber question
About 2 months ago, a body shop did some work on my car and had to remove the rocker panel rubber. Well, I JUST NOW noticed that on the driver's side there's about 1/8" in the middle of the rubber that's pulled away from the car. The passenger side is perfect and I know the driver's side was fine before this "repair". Could this cause a problem with rust or anything?
Matt
'82 911SC Targa!
Old 09-15-2003, 07:26 PM
jyl jyl is online now
jyl's Avatar
If it's the same as my 89, the rocker rubber strip has a groove that mates up with a lip on the metal rocker panel. Maybe the groove has become dislodged, or there is some debris stuck in there.
You might try pushing it back, or even removing the rocker panel (unscrew caps at either end, then several screws through the bottom edge of the panel) and re-seating the rubber strip.
Old 09-15-2003, 07:47 PM
911S Targa's Avatar
I know, old thread, but why make another thread.,..,
On topic. Seems my cap ends aren't screwed on, but rivited on. How does one remove the rivits ?
Bill
MID9 #4
if i cant play with it ,,i dont want to own it
Old 09-23-2005, 06:35 PM
I have always removed rivets with a drill. Use a large bit so you're grinding away the head. Afterwards, pop rivet guns aren't very expensive Sears, etc.), or you might can use a sheet metal screw.
Scott Wilburn
1988 911 Carrera 3.4 L
1998 M3
1984 308 QV
Old 09-23-2005, 06:38 PM
911S Targa's Avatar
Well I actualy have a pop rivit gun, and rivits (thanks dad).
So if I grid away the head, it will fall into the inside ?
Bill
MID9 #4
Old 09-23-2005, 06:45 PM
Yes. You may have to use some light taps with a punch and hammer, but once the head is gone what is left will go back through the hole. Look at an used rivet and it will make sense. The outer head is formed at the factory. The inner one is formed when you pull the nail looking thing (don't know the proper term). You end up with a narrow shaft with expanded heads on both ends.
Scott Wilburn
1998 M3
1984 308 QV
Old 09-23-2005, 06:54 PM
911S Targa's Avatar
Thanks for the info.
Bill
MID9 #4
Old 09-23-2005, 07:31 PM
