durn for'ner
livi's Avatar
How does it work, then ??
Most of the strictly mechanical parts on the Porsche, like shocks, sway bars, brakes etc - even I can grasp at least the fundamentals of how it works.
Engine i another matter. I have no former training what so ever and I am getting more frustrated every time I try to follow a thread on an interesting engine topic - technical terms flying all over - and I donīt have a clue what you guys are talking about.
I want, no I need... I canīt go on as a proud Porsche fanatic if I donīt learn at least the basics.
I fully understand you canīt properly get the hang of it with out the practical training - but reading up would at least give me some clue.
So, could you recommend any books or other literature that teach the basics in how the engine works - preferably the Porsche engine.
Thanks,
Markus
Resident Fluffer
Carrera '85
Old 09-23-2005, 02:27 PM
Driving member
jester911's Avatar
Maybe this will help a bit.
Animated Porsche MFI engine is here!
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 09-23-2005, 02:47 PM
durn for'ner
livi's Avatar
Thanks Jerry,
I saw that impressive work when he posted it.
BTW what ever happened to Darryl, donīt think I have seen him around lately.
Markus
Resident Fluffer
Carrera '85
Old 09-23-2005, 03:35 PM
randywebb's Avatar
You put some air (oxygen) & some flammable material (gas) into the cylinder and blow it up (sorta). That "explosion" causes the pressure to go up and the walls and top of the cylinder won't move, so the bottom - the piston - does. As the piston pushes down, it is attached to a lever that is part of the crankshaft. Since the lever is offset, it tends to make the shaft rotate. Now, connect a few more cylinders to it - in line - to make things smoother & voila!
Is that more or less what you are looking for? Or do I need more Burgandy (?) Get a model kit called the Visible V-8 or Visible Slant Six - if not at a Toy & Hobby store, they can prob. be had at Edmunds Scientific.
The above is a crazy way to make a wheel go around... Hence Lohner's and old man porsche's fascination with electric motors. Think about it - waht you really want is to create a rotational force field - exactly what an electric motor does... we just have to perfect it...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 09-23-2005, 06:10 PM
durn for'ner
livi's Avatar
Randy and Wayne,
Thanks for the input !
How long till I can skip the doctor thing (tough nights) and start my own Porsche engine rebuild enterprise ?
Markus
Resident Fluffer
Carrera '85
Old 09-24-2005, 04:29 AM
randywebb's Avatar
Sure - just post again to revive this thread if you have questions later - the next thing after this is 2 vs. 4 cycle and how to put valves on the thing to get air & gas in but then close them so you can compress or expand the mixture...
It is truly an infernal combustion machine -- amazing that we have made them work as well as they do. I'll miss them when they're gone - if I'm still around to miss anything by then...
Old 09-24-2005, 01:40 PM
HarryD's Avatar
Whenever I get a question like this, www.howstuffworks.com often is very informative.
For engines, try this: http://auto.howstuffworks.com/engine.htm
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 09-24-2005, 10:16 PM
