-   -   Engine lid hold down question (http://forums.pelicanparts.com/porsche-911-technical-forum/242865-engine-lid-hold-down-question.html)
David McLaughlin 09-25-2005 03:07 PM
Hot rods use hood pins to make the lid easier to remove. What is the 911 equivalent?
Jeff Alton 09-25-2005 03:18 PM
Hood pins......or rubber latches.
Jeff
Bill Verburg 09-25-2005 03:23 PM
http://forums.pelicanparts.com/uploa...1127686788.jpg
http://forums.pelicanparts.com/uploa...1127686971.jpg
David McLaughlin 09-26-2005 06:00 AM
Is there something that replaces the hinges too?
At one point I thought I had seen some sort of strap that allowed the engine lid to lay against the rear window. But then what would be the best to hold down the other end; these rubber latches?
jpnovak 09-26-2005 06:51 AM
hood pins and 911R style rear hinges. This will allow the decklid to flip onto the rear window.
72 four door 09-26-2005 09:14 AM
Where would you find these rubber hold downs?
Rot 911 09-26-2005 09:18 AM
They are sold lots of places. I don't think Pelican carries them, but Mossmotors.com does along with a number of online parts stores. A recent thread showed a number of sites. Do not pay 911R prices for them. A set should run you under $15.00.
jpnovak 09-26-2005 09:31 AM
Teh rubber hold downs can be found at just about any VW source that has baja parts. They are usually about $8-10 for a pair. Long ones for the front, short ones for the rear.
btw, I had rubber draw latches on the ST. They were attached to a fiberglass hood with no latch or backup. I found one loose after some spirited driving. They have now been removed and replaced with hood pins. mch more secure IMO. Other's have had no problems.
David McLaughlin 09-26-2005 01:27 PM
Thanks for the info guys. Now I just need to find some more close up pics and either buy or fabricate a 1/3 scale set for my son's 964 turbo.
Bill Verburg 09-26-2005 02:05 PM
http://forums.pelicanparts.com/uploa...1127768593.jpg
http://forums.pelicanparts.com/uploa...1127768524.jpg
http://forums.pelicanparts.com/uploa...1127768716.jpg
David McLaughlin 09-26-2005 02:58 PM
Thank you Sir Bill.
