Spanner size for rear e height adjust.
Two part question
1) How much ride height range is there by loosening the torison bar plate bolt and eccentric bolt. 2) What is the size of the spanner I need to adjust the large eccentric bolt on the inside of the plate?? Thanks |
1. You should be able to get 1/2-3/4 either way adjusting the eccentric. This will raise/lower the car, but will upset the balance if has been set.
2. 36mm, go you your local bike shop and buy a thin 36mm head wrench -B |
Thanks appreciated.
,as well as input on coner bal. i doubt it has been set,so I will adjust with the eccentric first. Maybe a corner balance for Christmas.after SSI and Chain Tensioner install |
| All times are GMT -8. The time now is 03:20 PM. |
