ecm911's Avatar
Wheel spacer ? - Too Big???
Hello,
I am looking to fit 17 " 2002 996 wheels on a 78 SC. In test fitting , they would fit with a least 1.5 inch spacer,maybe more like 1.75 inches.
My question, is there a problem with too big a spacers? It is a track car so i am worried about too much stress on things.
Thanks,
earl
78 SC Coupe
93 RSA (Gone)
Old 09-28-2005, 08:04 AM
jdowty3's Avatar
I've seen spacers for turbos that were up to 3 inches. If your going to track the car, you need to know what is allowed. Some allow spacers with built in studs and some require spacers that use long studs. If you get spacers with studs, get the stronger 7075 alloy instead of 6061.
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 09-28-2005, 09:59 AM
Is the bolt pattern the same???
2004 996 TurboS Cab
2005Cayenne Turbo S
1988 930 Turbo Cab
2004 BMW M3
2007 Range Rover Sport
Old 09-28-2005, 10:55 AM
ecm911's Avatar
Yes bolt pattern is the same.
Thanks if I do it I will get the spacers with studs ( 7075).
I was wonder what additional stress and on what is created by spacers.
Earl
78 SC Coupe
93 RSA (Gone)
Old 09-28-2005, 10:58 AM
No additional stress on your suspension since the centerline of your wheels remain the same.
Joe
Old 09-28-2005, 05:42 PM
