-   -   Too many grounds off one point (http://forums.pelicanparts.com/porsche-911-technical-forum/243358-too-many-grounds-off-one-point.html)
bfrenz 09-28-2005 08:47 AM
I'm in the process off hooking up my 3.2 DME in my 914. Where my wires run, in regards to the grounds, is the same spot where I hook up my 914 grounds.
Can you have to many grounding wires pulling from one spot. Or should it be spread out.
Rot 911 09-28-2005 09:02 AM
As long as all the connections are clean it doesn't matter.
RoninLB 09-28-2005 11:06 AM
I use a line of thought that says it's not the actual number of wires but the number of connectors on one lug that is the envelope. My thinking could be all wet 'cause I think marine? I max at 4 terminals.
70SATMan 09-28-2005 11:28 AM
Theoretically it's better to have all grounds originate from one spot. It eliminates ground loops and varying potential in circuits due to ground currents. It's just not practical from a mechanical standpoint. The more lugs you introduce in any one connection to chassis, the more chances you have for degraded electrical connection.
coloradoporsche 09-28-2005 11:40 AM
Ground is ground.
RoninLB 09-28-2005 12:09 PM
I'm with Michael on this one.
randywebb 09-28-2005 12:50 PM
Au contraire, what you think is ground isn't always at the exact same potential - Michael has it right. Whether gnd loops can be an issue for whatever electronics are in your model car, I dunno.
Just stack them up until you feel like it is not good mechanically then find or make another ground star.
