locktite and headstuds make for a PITA!
the lowers are coming out.. the uppers are staying in what a PAIN IN THE BUTT cant seem to get the last picture to load... tools used: two nuts...PB blaster...vice grips.. propane torch... two 17's...breaker bar... pipe wrench... and a miller wire feed.. 4 letter words tools wanted: snap-on stud removal tool
SWB |
Irrationally exuberant
I apply the flame from a Mapp gas torch to the junction between the stud and the case to break the loctite free. About a minute of that and the studs come out without a fuss.
Baum Tool has an inexpensive one that I prefer to the chunky SnapOn one. The Baum tool # is 28K-10 "STUD PULLER-SQUEEZE TYPE-10mm" -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Somewhere in the Midwest
propane won't get it hot enough to melt the loctite...
MAPP gas or oxy-acet. I love Oxy-act....you will hear the loctite sizzle almost, and smoke, then a it's smooth as butter. If you let it cool it'll bit again, so you have to get the studs off right away. Once the loctite melts, a couple of nuts doubled with medium force is all you need. |
All done now.... but we were out of gas ... you can see the oxy-acet setup in the second picture...
the upper steels are in great shape... the lowers were dilivar(forget the spelling) and will be replaced with steel.
SWB |
I just did the same thing yesterday on my 80SC, replaced all 12 lowers. Used MAPP gas which took a good 5 minutes of heating each stud down the inside of the block along the line of the stud. Even then I don't think I fully liquefied the Loctite. Loctite must have been on sale in Germany on the day they assembled my motor as those buggers were in there! I was amazed to find the entire block was very warm to the touch once the last one was out! Don't forget to run a tap to remove the remnants.
next time use the oxy/acet in the cylinder bore adjacent to the stud threads, to melt the loctite. no swearing, and you're done in 20 minutes.
