Send a message via ICQ to AirJose
Tach connections Help!
I am installing an old '67 912 tach into a 70 karman Ghia. I need to find out the following three connections in the center of the tach. There are three wire connectors marked: (+12), (1) and (-) (minus sign)
Please help me and tell me where to connect them to
Old 09-28-2005, 08:45 PM
Yellowbird RS's Avatar
look this
X/A
Old 09-28-2005, 09:34 PM
POKDUB's Avatar
Assuming that we are working here without known circuit diagrams etc.
+12V a bit obvious, main battery circuit once ignition is turned on, meter your other dash dials / wires to locate a 12V feed.
(-) is ground, again meter for ground connection wire or install a ground link yourself.
1 remains your lead back to the negative link on the coil which sends the tach signal to the tacometer.
POKDUB
Porsche 911E
Old 09-29-2005, 02:15 AM
Porsche Crest
Thank you for the responses, now I got it!! you all have a great day!!! Jose
Old 09-29-2005, 05:24 AM
