Engine Worth It?
70 2.2L
-Broken timeing chain or something like that. (have not taken it apart or inspected further. Could be something else.) -Zenith Carbs -901 trans -Carrera tensioners -Needs rebuild. -No exhaust -6106193 stamped. $1200 What do you think? It will be going into a 70T project car that I am looking at getting. Lucas |
Sounds a little steep considering the possible damage inside if it doesn't turn over. These motors seem to be very common. I sold a good running '71 2.2 motor complete with exhaust and carbs and a good 901 gearbox with a brand new starter on it last year for around $1500 to give you a pricepoint. Good luck with your search.
Michael Sans Porsche...for now 2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy 2010 Subaru Forester X Limited - wife's daily driver |
It being local is a + also. The guy has tones of Porsche parts so If I want to swap something on the motor for something else then he would do it.
Would it be a good start if I wanted to upgrade it later on? |
It depends on what you want to do. I would recommend a case that has the piston oil squirters installed which I think didn't happen until late 1970 or 1971. If you plan to rebuild it you may just want to find a good 2.7 core with the 7R crankcase. I'm sure many others will chime in here for you with good advice.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Friend of Warren
Personally I would pass on this engine. Generally speaking a rebuild is going to run about the same dollars regardless of the engine, be it a 2.2 or a 3.2. I agree that you would be better off rebuilding a 2.7
Kurt V No more Porsches, but a revolving number of motorcycles. |
