DME relay Installation
I am planning to change my DME relay and was wondering if someone had a step by step for this. I know the relay is located under the driver seat but did not seem very accessible even with seat move all the way back. @ cylinder under the seat seems to be blocking the access.
Do I need to remove the seat???
87 Targa lexus RX300 Ford Expedition 84 Alfa Sprint Veloce (sold) 89 Renault 19 16 s (sold) |
NO, you don't have to remove the seat.
Look at the DME relay. There is 1 nut holding the Relay. You should be able to see it if you slightly push the cable plugged into the DME computer.
The Fox Carrera |
thanks will take a look today
