BTW: Don, very nice. Mulholland run once you get that sucka in place... ;) |
I believe it came with Cabs. Is this motor from a cab?
After re-reading the earlier posts, they now make sense. I was overlooking the cab references.
Honestly, the presence of the dampener had not registered with me till tonight. |
Don,
Assume that you got this from Jim??? Pictures of the repair on the car pls!!! JoeA |
Is that specific to a G50 car or a cab? I know there was some kind of harmonic balancer (maybe it was a dampener??) for the G50 cars.
Very neat looking
It is for cabs. The cross mount bar is also different.
Cheers |
Very nice Don! Looks like new. Any mods? What kind of HP do you expect?
The cab engine mount and cross bar are different for a cab. I would change them both if you can get a set easily. Another option is to remove the shock component and replace it with a 3/16" bar welded up to add the rigidity. I found the cab mount caused shifting difficulties under heavy load on the track. If you want I can take a picture of the set-up.
John |
Don,
Need to email you. Pls PM me your email. Thanks, JoeA |
Joe, PM sent.
About the dampener... what the recommended approach? Keep it? Change it to a solid piece of metel? At this point, I don't have a preference. |
| All times are GMT -8. The time now is 12:04 AM. |
