930 Front Brake Rotor Picture.......
Could someone please help me get a picture/s of a 930 front brake rotor either installed or disassembled? Looked at several 911 maintenance manuals without luck.
Thanks in advance. TD |
I can send you one...
Fronts
'78 -80 2 piece floaters floating hats ![]() '80-89 1 piece Rears
('80-'89) 1- piece rotors......
Bill V.,
The 1-piece rotor ('80-'89) shown above are for the rear? I was hoping to find a 1-piece OEM rotor (930) that I could convert/use in the front (brake upgrade conversion). What after market front rotor do you recommend with 993 caliper to be installed on SC car? I have a set for 993 calipers and rotors for both front and rear awaiting application. Thanks. Tony |
At least 4 ways to go for use w/ 993 front calipers you can modify your hubs and use 993 304x32 1 piece front rotors, I believe that Slider79 did this You can buy a set of 309x32 2 piece Wilwood rotors and hat from dinftown You can buy a set of 2 piece 304x32 Colaman rotors and hats from VCI You can buy a set of cut down 304x32 Brembos 2 piece rotors and hats form Steve Weiner
in the back you will want '78 -89 930 rear rotors w/ 965 or 993 rear calipers
I got 4 Options......
Bill. V.,
Thank you very much for the well written 4 options you have given me (us). They are very informative, clear, and concise. I couldn't have asked for more. It's just now a matter which direction to go. I have 3 sets of 911 Fuch wheels (6", 7" & 8") and believe none of these wheels will fit in any of the 4 options. I could be wrong. What wheel/s will work well for the above options (SC car)? Again, I would not have planned to take on this project without your guidance and help. Thanks. Tony |
6", 7" & 8" wheels......
All these wheels are 16" diameter 911 Fuch wheels. Prefer to stay 16" and save some of these wheels.
Tony |
W/911 7x16 you will need ~6mm spacer in front. w/ a 944 7x16 or 8 x16 you will need nothing.
The 993 set up will give you a huge increase in thermal reserves and potential brake torque, I would want 7 or 8 fronts w/ 225/50 and 9 w/245/45 x16 to take advantage of the increased stopping power.
since we're on the subject..... what are floating rotors and how do they work?
1972 VW super beetle (sold) 1997 Acura cl (sold) 1997 Toyota tacoma 4WD looking for that perfect porsche! |
This allowable "movement" serves several purposes.[list=1][*]allows more perfect alignment of the rotors w/ their pads[*]decouples the heat in the rotor from the hub[*]lightens the rotating assembly[*]allows for differential thermal growth of the rotating assembly[/list=1]
