Do I need to adjust fuel mixture?
Just had a Fabspeed euro pre muf and max flo sport exhaust installed. Now that there is no longer a cat are there any adjustments that need to be made to the mixture? Father in law says he smells fuel and that it should not pop during decel?
Reverend Ray
84 Carrera Coupe "DAS-V2"
GruppeB #2119
Volvo V70SE-Wife mobile
Nissan Frontier-Home Depot mobile
Old 10-01-2005, 06:00 PM
ausgezeichnet's Avatar
I had to adjust my mixture (lean it out) after replacing my cat with a pre-muffler. That took care of my excessive pop during decel.
Mike
'84 911 Carrera Coupe (totaled)
'83 911 SC Coupe
‘06 Aston Martin Vantage V8
Old 10-01-2005, 06:54 PM
Thanx Mike
Reverend Ray
GruppeB #2119
Old 10-02-2005, 03:22 AM
Make Bruins Great Again
Por_sha911's Avatar
Lack of Cat will make the exhaust smell richer. The muff will also cause a slight popping. If its not overly bad, leave it. If you are concerned, the best thing to do is to take it to a shop and have them do an exhaust gas analysis. The only thing worse than running a little rich is running too lean and burning a valve.
Joe
Old 10-02-2005, 09:15 AM
Do a search on how to set your mixture by measuring the voltage output from your 02 sensor. That's how I set mine.
Mike
'83 911 SC Coupe
Old 10-02-2005, 05:43 PM
