SLR SLR is offline
SLR
two out exhaust
Hi there all yet an other exhaust ??
I have spent some time looking at older threads and come up with zip.
I'm fitting a one in two out muffler and will have to modify the valance
has any one done this ? and if so and if you have pics would you please
post them
I bet I'm not the only one wanting to know and see this.
Thanks Steve.
Old 03-15-2003, 08:37 AM
Mikkel
Guest
Posts: n/a
Dickster has one. Others too. There must be something in the archives.
This thread is the only one I can remember: dansk system arrived - yeah baby
Unfortunately it's not what you're after.
Old 03-15-2003, 09:30 AM
Formerly bb80sc
Vipergrün's Avatar
No pics, but here is what I did...
Using your floor jack, lift the new muffler into place with the valance attached so the right side pipe is barely touching the valance. You cannot attach it, but you can line up the holes with the heat exchangers. Put a piece of blue painters tape (or other) on the valance where the right side pipe is. Once you have verified the alignment of the muffler you're ready to make the reference marks on the tape. I used a piece of cardboard to make a template of the left side of the valance, flipped it over to the right side and traced the cutout on the tape. Then, you just fire up a jigsaw fitted with the fine tooth metal cutting blade ands go for it. Make sure you support the valance while cutting it, it will bend if you're not careful. Use a bit of primer and touchup paint on the raw edge, not much is needed. When you are done, you should practically have a mirror image of the left side.
Good luck!
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 03-15-2003, 10:19 AM
Mark Wilson
Guest
Posts: n/a
SC with Flauwmeister sound file
Old 03-15-2003, 11:29 AM
Senior Member
Doug Zielke's Avatar
Originally posted by bb80sc
......When you are done, you should practically have a mirror image of the left side......
Except that the left side has factory-formed edges.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 03-15-2003, 01:00 PM
Bill Verburg's Avatar
Heres one
rear valance
Bill Verburg
Old 03-15-2003, 03:21 PM
SK SK is offline
SK's Avatar
here is mine
Old 03-15-2003, 08:17 PM
Randy Webb's Avatar
How loud are the twin exit mufflers compared to the single exit ones? What about resonance?
Old 03-15-2003, 08:19 PM
Mark Wilson
Guest
Posts: n/a
mpeg with sound of a Flowmaster dual out
Old 03-15-2003, 08:24 PM
dickster's Avatar
i used the same method as bb80sc. with a dremel for the cutting.
the two out dansk is loud, but no resonance.
Rich
'86 coupe
"there you are"
Old 03-16-2003, 12:54 AM
Mikkel
Guest
Posts: n/a
It's my impression that 1 in 2 out mufflers are not so loud. However 2 in 2 out mufflers are usually quite loud and can often suffer from annoying resonance.
They can also provide breathtakingly gorgeous sound. I heard a 993 varioram engine (in a 1972 911) with a custom made 2 in 2 out recently Absolutely wonderful, but also very very loud.
Old 03-16-2003, 01:11 AM
SK SK is offline
SK's Avatar
Mine is louder than OE, but not that loud. It sound very mean when you get on it..It is not as loud as many "Ricers".
I took my friend for a ride the other day...he also has an '85, but the sound pad/insulation in his engine comp. is gone. He said my new muffler was no louder than his OE muffler w/o the sound pad/insulation.
Old 03-16-2003, 04:41 PM
there are numerous threads on the mods needed to accomaodate a right side outlet, search IS your frind
Here's one
Bill Verburg
Old 10-02-2005, 07:00 PM
MAGA
Tim Hancock's Avatar
Here is a link to my 2 out conversion. After marking the valence, I took it off and simply used tin snips, then filed the raw edge, then rolled the edge in slightly, then touched up the edge with touch up paint. The seperate foward extending valance extension was left as is, although one could add a little piece to it to match the left side piece. You cannot see both side pieces at the same time, so why bother.DIY stock muffler mod, 1 out to 2 out, SC
PS: save the piece you cut off in case you ever want to re-attach it if you decide to go back to a single out.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 10-03-2005, 04:51 AM
