}{arlequin's Avatar
master cyl. actuating rod on the brake pedal?
I remember reading in the past about a LONGER version of the actuating rod that presses on the master cylinder plunger (goes inside it). I have the "normal" version of that rod. It screws into a threaded, pivoting coupler on the brake pedal arm, and presses on the master cyl. when brakes are applied.
I've installed a new master cylinder, different size from my previous stock 19mm and the brake pedal rod is too short, even when unscrewed as much as I dare to lengthen it.
Is anyone aware of the longer version of that part or maybe how to modify the existing one?
thanks.
dave
1973,5
Old 10-03-2005, 07:19 AM
I would rather be driving
jpnovak's Avatar
VCI has the rods and also the new feed lines to clear the steering cross member. I think Steve W at Rennsport also has them.
Old 10-03-2005, 07:31 AM
}{arlequin's Avatar
edit:
it is part # 21 in the diagram
dave
1973,5
Old 10-03-2005, 07:43 AM
}{arlequin's Avatar
thanks Jamie, I'll check with them
dave
1973,5
}{arlequin's Avatar
just b/c I "could", and also b/c I don't have any patience I've decided to make my own. Took a 5" bolt w/ the same thread and with the help of Pelicanite "jazzbass'" air grinder I went to town. Once I ground off the hex head, it was time to get fancy LOL
here's the rough finish:
and assembled w/ the full polish :
dave
1973,5
Old 10-04-2005, 01:39 PM
Bill Verburg's Avatar
if you buy a kit the rod comes w/ it
Bill Verburg
Old 10-04-2005, 01:55 PM
}{arlequin's Avatar
LOL, while I didn't get the kit, I did get the master from Steve Weiner but I guess I wasn't clear on the fact that I need that too. Do all years require this longer actuator or just the early cars?
dave
1973,5
Old 10-04-2005, 02:09 PM
All thru '76 need it. The other needed part is the angled feed fitting
Bill Verburg
Old 10-04-2005, 03:10 PM
}{arlequin's Avatar
LOL, you're on the money there! It is the only part that I'm not quite sure how to handle. Right now I have the angled feed fitting going into the grommet from the feedline. I have a slight drip coming from that connection. I think the problem is that the grommet on the feedline is designed to go *into* the master and not to accept another tube into it, at least not w/ a good seal. I think I'm going to do away w/ the grommet and use a piece of hose to connect the feed line to the angled fitting.
dave
1973,5
Old 10-04-2005, 03:24 PM
Yes, that is correct. Here is the kit
Bill Verburg
Old 10-04-2005, 03:43 PM
}{arlequin's Avatar
thanks again Bill. I'm glad that on my own I've managed to arrive at the reasonable solution and away from something ridiculous- my homebrew 'inventions' have a way of failing me
dave
1973,5
Old 10-04-2005, 03:47 PM
greglepore's Avatar
I think that the vci rod is just a metric bolt of the correct diameter with the head cut off and the cut radiused; at least that is what mine looks like.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 10-04-2005, 06:43 PM
}{arlequin's Avatar
in that case Greg, it's only about a 1/2 hour worth of time w/ a well-powered grinder
dave
1973,5
Old 10-04-2005, 09:23 PM
Just as a FYI here is the correct rod for the 23mm m/c
Bill Verburg
Old 10-10-2005, 03:14 PM
