durn for'ner
livi's Avatar
Smoke. Should I be worried ?
Carrera ´85. Euro. 87k. Engine never opened. Pulls like a train.
Mobil 1. 0w40. Only needs 1L / 3000 miles. Perfect oil level (mid mark). Good mileage.
I know a lot of our cars produce a short puff of smoke on upstart.
But. Mine produce rather much - white - smoke on upstart when cold. Tend to go on for at least 5 minutes. No smoke after that and no reported smoke on accell or decell when at op. temp.
I know, most of the signs on this patients Bill of Health sounds good. Just seems mine has a longer smoke window than most reports on upstart.
Anal ? Moi ??
Any input appreciated !!
Markus
Resident Fluffer
Carrera '85
Old 10-08-2005, 02:30 AM
rfuerst911sc's Avatar
If it were me I would switch to a heavier oil then the 0W and see if you get the same results. 0W is very thin plus being synthetic it may be getting past the valve guides until the motor warms up, everything else from your description sounds normal.
Old 10-08-2005, 05:31 AM
If it's any consolation, that puff is a sure sign of positive lubrication on startup, a critical time when most engine wear occurs.
Keep the 0W as insurance and peace of mind.
5W30 dino oil works for me and mine's an 86 3.2.
Cheers,
Joe
Old 10-08-2005, 05:49 AM
aj88cab's Avatar
Try letting the engine idle a few seconds until the oil level guage stablizes before you shut it off. This allows the oil to pump back into the tank. This has all but eliminated startup smoke on my (120k mi) Carrera.
Good Luck
Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 10-08-2005, 08:37 AM
Glasgow 911SC's Avatar
I use 0-40 Mobil1 too. It's good stuff in cold climates. White 'smoke' is more likely steam (condensation) burning off, no?
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 10-08-2005, 09:00 AM
Originally posted by Glasgow 911SC
...White 'smoke' is more likely steam (condensation) burning off, no?
True.
White is water condensation steaming off.
Black is too rich fuel mixture.
Blue/grey is oil.
-Steve
'87 Carrera Targa
Old 10-08-2005, 09:41 AM
durn for'ner
livi's Avatar
Thanks, guys
Good input - albeit a tad contradicting..
Andrew,
Thats the funny thing. I always stay put a couple of minutes for the oil the circulate and engine settle down - AND as long as I stay put the smoking continues - but as soon as I start driving the smoke vanish.
Markus
Resident Fluffer
Carrera '85
Old 10-08-2005, 10:16 AM
