Brake Lines and Flush
Ok, so I need to replace my soft-lines and flush my brake system. I'm not sure when it was previously bled/flushed, so I really want to make sure its cleaned out. My mechanic recommended that the system be throughly flushed to ensure that there isn't any "crap" in the lines.
So, question time: Should I flush the lines first, then change them, or go ahead and swap the lines first, then flush the entire system?
Also, any tips would be greatly appreciated.
Just for info, I was planning on getting the ATE Blue and Gold and run the blue through the system until it shows up, then run the gold through to make sure I flush out any crap that might be in there. I'm also going to get the pressure-bleeder and some speed-bleed valves to make the job easier.
-Chris
Old 11-15-2007, 07:28 PM
RETIRED
Joe Bob's Avatar
Pull the lines and then flush....I also do the blue/gold thing my self.
2012 ML350 3.0 Turbo Diesel
Old 11-15-2007, 07:31 PM
