-   -   CIS Blower testing (http://forums.pelicanparts.com/porsche-911-technical-forum/244643-cis-blower-testing.html)
75-911S 10-06-2005 09:10 AM
CIS Blower testing
Being electrical circuit challenged, could someone tell me which wires to connect to the + and - sides of a battery to test the blower that sits next to the CIS air box if it is off the car? My blower wires are brown and yellow with black stripes.
Thanks.
Jack
safe 10-06-2005 09:45 AM
Meassure in the contact with a tester.
I'll make a wild guess and say itīs toast :)
wilke3169 10-06-2005 10:03 AM
http://www.pelicanparts.com/911/911_Parts/911_electrical_diagrams.htm
These diagrams will help. My suggestion as a fellow SC resident is to throw it away and backdate. Plenty of heat for our winter here.
safe 10-06-2005 10:34 AM
Yeah, throw that crap away.
I made a T piece and connected the hoses to. I will get the proper parts later.
http://forums.pelicanparts.com/uploa...1128619920.jpg
75-911S 10-06-2005 11:25 AM
Thanks for the link to the wiring diagrams. But they are Greek to me. I still need to know if the brown or the yellow wire is the "hot" one. If the blower is still good I don't want to damage it.
Jack
wilke3169 10-06-2005 11:40 AM
I'm betting brown goes to negative terminal. I don't think it would hurt anything if connected backwards. Should be a path through either way according to the diagram, unless the motor is shorted to ground. I will check when I get home I do believe I have an old removed motor in the garage somewhere.
75-911S 10-06-2005 12:20 PM
Thanks Kevin. I appreciate your help.
Jack
safe 10-06-2005 12:55 PM
Itīs a dc motor it will just go the other way. brown is negative in the diagram from Haynes.
75-911S 10-06-2005 01:18 PM
Thanks guys. I gave it a shot of juice and it looks like Safe is right - it appears to be toast.
Jack
safe 10-07-2005 12:28 AM
The blower motor is always on when the engine is on a 75.
In 76 porsche (they noticed that the blower didnt live very long...) added a switch so its only on when you have pulled up the heater levers.
Check out this site.
Heater system
75-911S 10-07-2005 06:24 AM
Great info Safe. Lots of other tech articles on that same site.
I guess I must have made it through last winter without the blower and didn't realize it. Now I have to decide if I want to try to find another one and add an off/on switch - or get the hoses and couplers to backdate to the pre-blower setup.
Jack
safe 10-07-2005 06:51 AM
Glad I could be of help :)
The only difference between the blower and pre-blower setup is that the pre-blower donīt give you so much heat on lower rpms, you need to keep the engine above 3000 rpm.
But it looks way nicer without the hoses and you save a bit of weight where it counts :)
RoninLB 10-07-2005 07:40 AM
I back dated mine.
ianc 10-07-2005 04:25 PM
You'll need the blower if you spend time in traffic with the engine at low speed or near idle. If your motor is toast, forget about fixing it; I tried forever and gave up. New Porsche motors are extremely expensive, but you can adapt an inexpensive Grainger motor to work. See here:
http://forums.pelicanparts.com/showthread.php?s=&threadid=211760&highlight=blower +motor
ianc
