Kevin Taylor's Avatar
1983 911 Sc Wont Idle
Strange thing happened on the way to work yesterday.
Engine started normal and had idle normal but after I
let it warm up I and left the house and got to the first stop
light it died.
Started back up ok but now it wont idle at all. Had to drive to work and back using the emergency brake and revving it at stops.
The only thing that's different from the day before is the temperature. It's about ten fifteen degrees colder now.
Any Ideas?
Thanks K.T.
1983 911 SC
1973 911 E 2.4 MFI
1965 Devin "D" - 1967 912 Power Plant
Old 10-07-2005, 06:00 AM
Rick Lee's Avatar
Ah, the joys of CIS troubleshooting. How's your WUR? And loose hoses? How old's your fuel filter?
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 10-07-2005, 07:41 AM
Send a message via AIM to tony77targa
Hey Kevin
Im still learnin my CIS sys and have a couple cars arpound to xchange known good parts for suspect bad parts.... also you will probably get alot more help if you ask questions like thios in the bbs tech section...
Good luck !
Tony
89 Mercedes 300E
77 911s TARGA
79 3.2 widebody
79 911 SC TARGA
97 BMW Z3
Old 10-07-2005, 12:11 PM
ianc's Avatar
Sounds like a vacuum leak right off the top of my head. Any flapping hoses? Clamps on the air intake boot tight? Any cracks? Do you have a popoff valve installed and is it seated properly? Will it eventually idle when it gets warm enough?
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 10-07-2005, 01:43 PM
Porsche Head's Avatar
Have a spare WUR if you want, it's a rebuilt with ~3k on it.
1972 911E w/3.0 RS Replica
1988 M5 300hp
2016 Audi Q5 TDI
Old 10-07-2005, 01:51 PM
Thanks for your responses. I'm at work right now
so I'll fool around with it over the weekend. It has pop
off and it's seated. not sure about how old the fuel filter
is. Had to drive the truck today. It wont idle when warm either.
It got to dark on me to play around much last night. I was able
to check for vacume leaks but saw nothing. Will spend more
time with it in the day light with some help from my brother.
As if I did'nt have enough on my plate as it is. Just gutted the
bathroom and need to get back going on that project.
Thanks Again. Have Good Weekend All
K.T.
1983 911 SC
1973 911 E 2.4 MFI
1997 GMC 4X4 Z-71 SIERRA
Old 10-07-2005, 02:29 PM
