What's the difference between RS and SC flares?
If there is. |
there is....
from memory it is the shape of the opening when you look into the fender opening from the side can't remember which, but one or the other has a flatter top part that the other...this is exaggerated ![]()
"Are you out of your Vulcan mind?" Doug 2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS |
I thought it was more of the lip shape. right on the exterior 1/2 inch from the edge all around the fender lip the RS polls then bends under into the lip where the SC has a sharp crease then goes under the fender lip
For example if I got a grinder and held the sanding surface in the same plane as the wheel and pressed it against the fender...if you make it flat that is SC hope that makes sense MJ |
you're probably more correct MJ
I was doing it from memory...too many brain cells gone...
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
WOW,
Thanks for answers guys. So they are different , well for purist. But if I have SC flares on my RS clone it's fine? Most people don't know that. Thanks again guys! |
Hello Pierre!
I have SC flares on mine too ! How are you and your family! the weather for this weekend is very bad and I want to make a fall run but it will be for the next week ! I work presently on a spare weber set and I want to try on my car before winter coming . are you have time for removing your spring plate ? Bonjour ! Ray english lesson's part one !
1960 356 BT-5 Aetna blue 1973 911 RS récréation 1960 VW panel Dove blue 1971 914 barn find ! |
Hey!
Bonjour Ray, Longtime, Na, still no time for finishing the S. Plates. So you have SC too! cool. Hey, about the porsche catalog and James Dean? As-tu lu un peu? And come see us ( with the RS ). I wanna ride! ![]() |
Thread Tools | |
Rate This Thread | |
