Exclamation RS flares
What's the difference between RS and SC flares?
If there is.
Old 10-07-2005, 10:22 AM
skinnerd's Avatar
there is....
from memory it is the shape of the opening when you look into the fender opening from the side
can't remember which, but one or the other has a flatter top part that the other...this is exaggerated
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 10-07-2005, 04:19 PM
Send a message via AIM to 82SC
I thought it was more of the lip shape. right on the exterior 1/2 inch from the edge all around the fender lip the RS polls then bends under into the lip where the SC has a sharp crease then goes under the fender lip
For example if I got a grinder and held the sanding surface in the same plane as the wheel and pressed it against the fender...if you make it flat that is SC
hope that makes sense
MJ
Old 10-07-2005, 04:28 PM
skinnerd's Avatar
you're probably more correct MJ
I was doing it from memory...too many brain cells gone...
Doug
Old 10-07-2005, 04:31 PM
Rear Flares - their Taxonomy, Systematics and Evolution
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-07-2005, 04:35 PM
WOW,
Thanks for answers guys.
So they are different , well for purist.
But if I have SC flares on my RS clone it's fine?
Most people don't know that.
Thanks again guys!
Old 10-07-2005, 08:48 PM
Raynald's Avatar
Hello Pierre!
I have SC flares on mine too !
How are you and your family! the weather for this weekend is very bad and I want to make a fall run but it will be for the next week !
I work presently on a spare weber set and I want to try on my car before winter coming .
are you have time for removing your spring plate ?
Bonjour !
Ray
english lesson's part one !
1960 356 BT-5 Aetna blue
1973 911 RS récréation
1960 VW panel Dove blue
1971 914 barn find !
Old 10-08-2005, 05:56 AM
Hey!
Bonjour Ray,
Longtime,
Na, still no time for finishing the S. Plates.
So you have SC too! cool.
Hey, about the porsche catalog and James Dean?
As-tu lu un peu?
And come see us ( with the RS ). I wanna ride!
Old 10-08-2005, 07:31 AM
