jpahemi's Avatar
Cutting Bilstein shock stop
Can anyone tell me what's the safe amount one can cut the rubber bump stops on the Bilstein Sport shocks? The car is lowered to a level slightly lower than Euro, but not quite race.
Removing them will definately cause damge should the shock bottom.
Pics show front and rear stops; it looks like you can cut them in sections.
Front:
Rear:
TIA.
j.p.
Old 10-07-2005, 09:59 PM
randywebb's Avatar
JP - I think SRP has instruction on the pdf at their web site.
My bet is that the amt. that is safe to cut depends on how big a bump you hit...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 10-07-2005, 10:34 PM
jpahemi's Avatar
Thanks Randy.
Found the info I needed.
j.p.
Old 10-07-2005, 11:10 PM
aj88cab's Avatar
I may be way off base here but I seem to recall that when I installed by Bilstein Sports I spoke to the factory and they said that the Bilsteins have internal bump stops and do not require the factory bump stops. I'm pretty sure I did not reinstall mine. Please don't rely on my memory though, call the factory.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 10-08-2005, 06:59 AM
Todd Simpson's Avatar
The rears have an external bump stop.
The front Bilstein inserts for the *Boge* struts have an internal bump stop. The shaft is sealed in that application and you couldn't add a bump stop even if you wanted to.
The above pic appears to show a bilstein insert for a bilstein strut, those do have an external bump stop that should be shortened for lower applications.
Smart Racing instructions
http://www.smartracingproducts.com/pdfdocs/bilstein_rubbershock_front.pdf
http://www.smartracingproducts.com/pdfdocs/bilstein_rubbershock_rear.pdf
edited for spelling!
Old 10-08-2005, 07:15 AM
aj88cab's Avatar
Mine were indeed inserts for the factory Boge struts. Thanks for the clarification Todd.
Old 10-08-2005, 07:38 AM
