i have this recurring problem and am seeking sage advice..my driver's side turn signal light in particular always seems loose in the barrel of the socket so that it intermittently stops working..a real pain. what do you guys do to secure your bulbs? i'm using the correct one, but this sockets suck..
![]() ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
Wrap foil around it.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
Possibly, build up the bulb with solder to make it a tighter fit. I was dealing with the same problem this weekend with my 74.
what I did
removed the whole gizmo paying attention to where the internal faston connectors attach. Then operated on the spring area of the housing so the spring regains its pressure. I sliced the backside outside socket housing with a fine thin file to attach some small dia safety wire to reinforce it. Get in there and fake the job or you'll spend big bucks for a new one. I assume a used one is also worn. If you come up with a bright idea let me know. The socket reinforces my prejudice again that porsche electrics suck. That socket is made to fall apart eventually. Also the Euro bulb is a sloppy fit by design. And Ryan, do it on a day when you have time to be patient.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
it's true..the rear of the bulb housing is made of that tough paper and pops out easily..i secured my loose ones by reinforcing them with jb weld of all things, but it seems to hold. still doesn't solve the problem of the loose fit inside. i've tried bending the contact to put more pressure on the bul, but that alone hasn't solved it. i'll investigate these ideas, foil included.
ryan
Had the same problem....yep real pain. I used the solder method, just added a touch of solder to the contacts on the bottom of the bulb. Now this does not make the bulb fit tighter but it eliminates the problem of the lights working intermittently.
KC 88 Guards Red Targa (sadly sold )2005 Boxster S 1st Porsche 73 914 (long gone) |
Ryan,
I would say this may take a multi-pronged approach to conquer the problem entirely! Patince will be necessary ... so don't get in a hurry! 1. Do what you can with the sockets, individually ... 2.Either get new bulb(s) or replace some with particularly loose fit, and work to 'rehab' ones with better fit and the potential to be 'helped' by selective application of additional solder at the contacts and also on the sides with small bumps at 0°, 120°, & 240° to improve the tightness of fit to each individual socket. The nice thing about solder is that it is very easy to file down with a triangle file! And, if you go too far, you can always build it up again and start the iterative process of fitting again.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
are you guys saying to 'build up' the solder contact, and warren to make solder points on the side of the bulb to try and keep it from wobbling in the barrel? i don't guess anyone has a pic of what's being described?
ryan
Ryan,
Please post back what method you used and if it worked. I'm having the exact same problem. Tried foil, but so far no luck... Brian (go hogs)
1987 BMW 528e |
Driving member
I have had the same problem with the same side light.
Last time it went out I used a big gob of dielectic grease on the sides and the end. It has held about 3 weeks so far.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
