master cyl. actuating rod on the brake pedal?
I remember reading in the past about a LONGER version of the actuating rod that presses on the master cylinder plunger (goes inside it). I have the "normal" version of that rod. It screws into a threaded, pivoting coupler on the brake pedal arm, and presses on the master cyl. when brakes are applied.
I've installed a new master cylinder, different size from my previous stock 19mm and the brake pedal rod is too short, even when unscrewed as much as I dare to lengthen it. Is anyone aware of the longer version of that part or maybe how to modify the existing one? thanks.
dave 1973,5 |
I would rather be driving
VCI has the rods and also the new feed lines to clear the steering cross member. I think Steve W at Rennsport also has them.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
edit:
it is part # 21 in the diagram
dave 1973,5 |
thanks Jamie, I'll check with them
dave 1973,5 |
just b/c I "could", and also b/c I don't have any patience
I've decided to make my own. Took a 5" bolt w/ the same thread and with the help of Pelicanite "jazzbass'" air grinder I went to town. Once I ground off the hex head, it was time to get fancy LOLhere's the rough finish: ![]() and assembled w/ the full polish :
dave 1973,5 |
if you buy a kit the rod comes w/ it
LOL, while I didn't get the kit, I did get the master from Steve Weiner but I guess I wasn't clear on the fact that I need that too. Do all years require this longer actuator or just the early cars?
dave 1973,5 |
dave 1973,5 |
thanks again Bill. I'm glad that on my own I've managed to arrive at the reasonable solution and away from something ridiculous- my homebrew 'inventions' have a way of failing me
dave 1973,5 |
I think that the vci rod is just a metric bolt of the correct diameter with the head cut off and the cut radiused; at least that is what mine looks like.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
in that case Greg, it's only about a 1/2 hour worth of time w/ a well-powered grinder
dave 1973,5 |
Just as a FYI here is the correct rod for the 23mm m/c
