HFR_Racer's Avatar
Door switch inop. Do I have to remove the fender?
Has anyone changed out an A-post door switch (this is the switch that is activated by the door to turn on the interior lamp)? Do I have to remove the fender to change it out or does it just pop out of the panel? Any photos on this operation would be helpful..
I need to replace my right-hand door switch.
Thank you,
HFR_Racer.
Thank you,
HFR_Racer
'87 930, 3.3 liter, K27 hybrid, Kokeln IC, Andial, B&B, Borla, 17" Supercups.
Old 10-10-2005, 07:15 PM
No, it unscrews rearward. Pull off the rubberboot; loosen the lock nut and unscrew it. Don't let the wire pull back into the door post.
Old 10-10-2005, 07:18 PM
HFR_Racer's Avatar
Thanks Jim....
Does this have anything to do with my trunk lamp harness short? They are in the same circuit?
Thank you,
HFR_Racer
Old 10-10-2005, 07:19 PM
Possibly; just read your other post. Now getting out my wiring diagrams. 25 amp fuse is a bad sign. More later.
Old 10-10-2005, 07:25 PM
See your other thread. Jim
Old 10-10-2005, 07:58 PM
