TDC 1or 4
Hello, my rebuild is nearing completion and is all sealed up. I'm pretty sure my engine is sitting at TDC for #1. The distributor is not yet installed. Is there any way to verify it is on #1 without popping the valve cover again?
Thanks, Joe
BTW Wayne refers to the FE mark on the crank pulley, what does this stand for?
Old 10-10-2005, 10:34 AM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
Cant think of any.......
Just take one intake cover off. Its only 6 nuts.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 10-10-2005, 10:37 AM
or take #1 plug out, install a hose for a compression gauge and rotate the engine clockwise until pressure comes out of the hose. next mark up on the pulley will be #1 TDC. ( not to be confused with the full advance mark).
206 637 4071
Old 10-10-2005, 10:50 AM
Unregistered
sammyg2's Avatar
JW beat me to it, that's how I did mine.
The compression guage won't build up much pressure when rolling over by hand but it will show a few pounds which is enough to identify the compression stroke.
Old 10-10-2005, 11:32 AM
Thanks, guys. I just wanted to be sure. I took off the valve covers and it was already on one. I am just setting up the timing on the MFI pump and found the FE mark. I will put the distributor in ASAP to avoid this situation again. Getting real close. A little bit o wiring and exhauxt system to basically finish.
thanks, Joe
Old 10-10-2005, 11:45 AM
http://www.northerntool.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=6970&productId=200318185&R=200318185
I don't think our host sells one of these last time I checked.
Mark
'88 Carrera GPW Sunroof Coupe
'82 SC Targa (RIP)
Old 10-10-2005, 11:51 AM
