DME trouble?
Do DME relay's go bad? My 1990 911 shuts off when I stop at red lights, stop signs, etc.? The guy that had the car before me changed the DME, O2 oxygen sensor, set fuel mix, and replaced the idle speed control valve. It is still doing the same thing. Any suggestions.
Old 10-12-2005, 10:19 AM
durn for'ner
livi's Avatar
If the DME is shot I donīt think your car would start at all.
Head temp sensor ??
Markus
Resident Fluffer
Carrera '85
Old 10-12-2005, 10:30 AM
The car starts and runs fine until I come to a stop. It is especially frustrating when I slow down (coming down a hill or mountain) and the engine shuts off.
Old 10-12-2005, 10:39 AM
Not Quite Banned
Thomas Owen's Avatar
Idle switch possibly. Check this thread over on Rennlist: http://forums.rennlist.com/rennforums/showthread.php?t=224986&highlight=idle+switch
Post your findings...
Good luck.
Thomas Owen
1972 911T
1972 911S
Old 10-12-2005, 12:26 PM
jakermc's Avatar
Yes, DME relays go bad and its a common problem. If you still have the original DME, you are due for a failure. The problems you describe could very well be caused by a bad relay. When they die, they act intermittently versus a sudden and absolute death.
1983 911 3.6L - NASA GTS-3 class
1998 Boxster - PCA SpecBoxster, NASA GTS-2
2003 996X51 - NASA GTS-4, PCA GTB
2003 996 Carrera 2 Coupe
2003 Ferrari 575M
Old 10-12-2005, 12:44 PM
It was changed out last year. Is is possible that it is out again?
Old 10-13-2005, 08:52 AM
jakermc's Avatar
That would be very unusual. I'd probably start looking elsewhere for the problem. My 968 had a similar problem and it was certainly electrical in nature, it may have been the DME itself and not the relay. I'll check the invoice (dealer fixed it) and see what it says.
In the meantime, check all the connections in and out of the DME box and make sure they are clean and tight. Corrosion is another possible cause of the symptoms you describe.
2003 Ferrari 575M
Old 10-13-2005, 09:01 AM
Coral Red Syd's Avatar
DME could very well go bad in a year's time. It's a low cost replacement and replacing it will eliminate it as a fault variable.
Coral Red Syd - "For Those Who Love to Fly... On The Ground"
Old 10-13-2005, 09:21 AM
Change your plug wires. I had an Audi 4000 withthe same problem.
Lots of arching, visible at night only, nothing in the day, that was causing the cars electrical system to shut off similar to yours.
Maybe watch it run in the pitch dark night.
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted.
Old 10-13-2005, 09:24 AM
Check to see if the idle control unit is being switched on when the throttle is closed.
With the engine stopped, open the throttle a little by hand and you should hear the switch. Verify operation at the connection to the Idle Speed Control.
For starters, increase the idle speed by turning the control screw on the front middle of the throttle body'
Ned NYNA 11
87 Carrera targa
98 BMW 528i
98 Volvo V70
Old 10-13-2005, 10:47 AM
