-   -   front end alignment specs (http://forums.pelicanparts.com/porsche-911-technical-forum/245836-front-end-alignment-specs.html)
na2ub 10-13-2005 06:28 AM
I don't have my Bentley on me, but, what are factory specs for 79 SC alignment (front and back). I am getting an alignment soon, and would like to set everything slightly more aggressive than stock.
I am considering -0.5 front camber, -1.0 rear with the front and rear set to 0 toe. Will this make the front way to darty on the street? Maybe 1/32 toe in on the front would be more appropriate, but I hate scrubbing the tires in the parking lot.
I believe the rear is -1.0 factory spec, and have worn nice and even on my last set of tires.
Yes, I did a search, and everyone does it differently. The car will be 90% street.
Doug
imcarthur 10-13-2005 06:55 AM
The factory specs are shown on the sheet below. In between the arrows . . .
Ian
http://forums.pelicanparts.com/uploa...1129211702.jpg
na2ub 10-13-2005 11:01 AM
Thanks, imcarthur!
So, if the front is spec'd at 0 degrees camber and the rear at -1, should I increase both by .5, making the front -0.5 and the rear -1.5? I am leaning toward setting the front and rear toe to 0, but will this make the car to darty? I like to drive, so I don't mind keeping at least one hand on the wheel.
