-   -   Is the G50 cranky getting into second before warmed up? (http://forums.pelicanparts.com/porsche-911-technical-forum/245911-g50-cranky-getting-into-second-before-warmed-up.html)
dorschman 10-13-2005 12:56 PM
87 carrera, is a little reluctant to shift into second before the engine is warmed up. All other gears seem fine. Nothing heard, just a little grind going into second, more noticeable under 3k rpm.
Seems to disappear when the engine is warmed up.
Is this normal or could I have an underlying problem? Does not seem to have worsened in the three months that I have owned the car.
thanks.
jorian 10-13-2005 01:10 PM
My tranny (also 87 G50) has always been "reluctant" to shift up into 3rd and grinds if I go too fast. Happens whether car is warm or cold. Doesn't bother me so I haven't investigated further. Do a search on "G-50 shifter bushings" or "G-50 clutch fork upgrade". Your car may or may not have this upgrade which seems to be recommended by many on this board.
Tyson Schmidt 10-13-2005 01:16 PM
They also like synthetic gear lube. Don't use Swepco in a G-50. Too slippery and thick when cold for the Borg-Warner type synchro's to work properly.
imcarthur 10-13-2005 01:21 PM
Definitely likes to be warmed up. Smooths out after 5 minutes. I'm using Redline Synthetic which helped but didn't cure warmup or the g50 rattle/whine noise.
Ian
arerrac 10-13-2005 01:24 PM
Have the same issue with mine first thing in the morning. I just blip the throttle a little bit to help the syncros engage going into second. Just a little blip.
-W
Tyson Schmidt 10-13-2005 01:27 PM
Ian
If you use Redline, make sure it says NS on the bottle. Otherwise it has a friction modifier for LSD's that will be similar to the additive in Swepco that makes it too slippery for the synchro's to work properly.
imcarthur 10-13-2005 01:33 PM
Thanks, Tyson. 75W90 NS is what I used. Although I read in a post here or on Rennlist that a Pcar owner at Redline has suggested a blend of NS & their slip variant was ideal. I might try it after the winter sleep.
And to clarify my cold shifting - it doesn't grind but it feels very mechanical when cold - you can feel the metal . . .
Ian
TMH 10-13-2005 01:35 PM
Began to have the issue in the '87 track car - don't remember whether it was 2nd or 3rd.
Changing fluid Redline resolved the situation completely. Great stuff. Used 100% Redline (75W90 NS IIRC), but after that my wrench actually suggested using 50:50 Redline:Mineral Gear Oil.
Tom
Tyson Schmidt 10-13-2005 01:42 PM
Yeah, even with the right oil, sometimes they're just cranky when cold. Just a sign of some normal wear.
JeremyD 10-13-2005 01:43 PM
I changed my gearbox oil - 56,000 miles 87 - it was getting a little notchy going into 2nd gear when cold - changed to Mobil one and it's smooth like butter now!
JeffO 10-13-2005 01:47 PM
My 1988 G-50 is slightly heavy feeling from 1st to 2nd to 1st. Sounds like a good winter project, anyone have proven results using redline and mineral oil ?
Geary 10-13-2005 01:51 PM
Mobil 1 is recommended over Redline. But for the best protection of R&P and gear faces, Swepco can't be beat -- even though the G50 synchros are better suited to synthetics.
KobaltBlau 10-13-2005 01:55 PM
do any of you folks with the 75w-90ns red line have a limited slip? do you get any limited slip grabbing/chatter with the red line or did you with other oils?
jorian 10-13-2005 01:56 PM
Tyson,
What do you think of Mobil 1 over others? My car also has LSD.
Geary 10-13-2005 03:15 PM
I'll chime in there -- Not a single ALMS car uses Redline. All use Mobil 1.
Dixie 10-13-2005 03:24 PM
Is that because Mobil is an ALMS sponsor?
cicsprog 10-13-2005 03:28 PM
Same issue with mine....Mobile 1 helps for sure!
Jason
88 CAB
Tyson Schmidt 10-13-2005 03:34 PM
I totally agree with this.
Tyson Schmidt 10-13-2005 03:36 PM
If you have an LSD, then you can play with the mixture of NS and regular to adjust the LSD's effectiveness. But you should use at least one quart of regular which contains the friction modifier.
cbeers 10-13-2005 03:49 PM
Re-edit:
Tyson,
My car is an '87 with an LSD, for Redline, I should NOT get the NS type right?
thanks
Chris
