dorschman's Avatar
Is the G50 cranky getting into second before warmed up?
87 carrera, is a little reluctant to shift into second before the engine is warmed up. All other gears seem fine. Nothing heard, just a little grind going into second, more noticeable under 3k rpm.
Seems to disappear when the engine is warmed up.
Is this normal or could I have an underlying problem? Does not seem to have worsened in the three months that I have owned the car.
thanks.
87 911 coupe "Katy"
Summer Yellow
Linen Mahogany interior
04 Pilot "The Pilot"
Old 10-13-2005, 12:56 PM
Registered Cruiser
jorian's Avatar
My tranny (also 87 G50) has always been "reluctant" to shift up into 3rd and grinds if I go too fast. Happens whether car is warm or cold. Doesn't bother me so I haven't investigated further. Do a search on "G-50 shifter bushings" or "G-50 clutch fork upgrade". Your car may or may not have this upgrade which seems to be recommended by many on this board.
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 10-13-2005, 01:10 PM
PRO Motorsports
Tyson Schmidt's Avatar
They also like synthetic gear lube. Don't use Swepco in a G-50. Too slippery and thick when cold for the Borg-Warner type synchro's to work properly.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 10-13-2005, 01:16 PM
Used Up User
imcarthur's Avatar
Definitely likes to be warmed up. Smooths out after 5 minutes. I'm using Redline Synthetic which helped but didn't cure warmup or the g50 rattle/whine noise.
Ian
'87 Carrera Cab
Old 10-13-2005, 01:21 PM
arerrac's Avatar
Have the same issue with mine first thing in the morning. I just blip the throttle a little bit to help the syncros engage going into second. Just a little blip.
-W
"88 Commemorative Edition Carrera - RIP
replacement - "90 Carrera 4
Old 10-13-2005, 01:24 PM
PRO Motorsports
Ian
If you use Redline, make sure it says NS on the bottle. Otherwise it has a friction modifier for LSD's that will be similar to the additive in Swepco that makes it too slippery for the synchro's to work properly.
2004 GT3
Old 10-13-2005, 01:27 PM
Used Up User
imcarthur's Avatar
Thanks, Tyson. 75W90 NS is what I used. Although I read in a post here or on Rennlist that a Pcar owner at Redline has suggested a blend of NS & their slip variant was ideal. I might try it after the winter sleep.
And to clarify my cold shifting - it doesn't grind but it feels very mechanical when cold - you can feel the metal . . .
Ian
'87 Carrera Cab
Old 10-13-2005, 01:33 PM
TMH TMH is offline
TMH's Avatar
Began to have the issue in the '87 track car - don't remember whether it was 2nd or 3rd.
Changing fluid Redline resolved the situation completely. Great stuff. Used 100% Redline (75W90 NS IIRC), but after that my wrench actually suggested using 50:50 Redline:Mineral Gear Oil.
Tom
Ain't life grand?
Old 10-13-2005, 01:35 PM
PRO Motorsports
Yeah, even with the right oil, sometimes they're just cranky when cold. Just a sign of some normal wear.
2004 GT3
Old 10-13-2005, 01:42 PM
MBruns for President
JeremyD's Avatar
I changed my gearbox oil - 56,000 miles 87 - it was getting a little notchy going into 2nd gear when cold - changed to Mobil one and it's smooth like butter now!
Old 10-13-2005, 01:43 PM
JeffO's Avatar
My 1988 G-50 is slightly heavy feeling from 1st to 2nd to 1st. Sounds like a good winter project, anyone have proven results using redline and mineral oil ?
"The smaller the fine print, the larger the risk."
1988 911 coupe
2008 VW R32
2004 530I
Old 10-13-2005, 01:47 PM
Geary's Avatar
Mobil 1 is recommended over Redline. But for the best protection of R&P and gear faces, Swepco can't be beat -- even though the G50 synchros are better suited to synthetics.
Old 10-13-2005, 01:51 PM
KobaltBlau's Avatar
do any of you folks with the 75w-90ns red line have a limited slip? do you get any limited slip grabbing/chatter with the red line or did you with other oils?
Andy
Old 10-13-2005, 01:55 PM
Registered Cruiser
jorian's Avatar
Tyson,
What do you think of Mobil 1 over others? My car also has LSD.
Old 10-13-2005, 01:56 PM
Geary's Avatar
I'll chime in there -- Not a single ALMS car uses Redline. All use Mobil 1.
Old 10-13-2005, 03:15 PM
Southern Class & Sass
Dixie's Avatar
Is that because Mobil is an ALMS sponsor?
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 10-13-2005, 03:24 PM
cicsprog's Avatar
Same issue with mine....Mobile 1 helps for sure!
Jason
88 CAB
Old 10-13-2005, 03:28 PM
PRO Motorsports
I totally agree with this.
2004 GT3
Old 10-13-2005, 03:34 PM
PRO Motorsports
If you have an LSD, then you can play with the mixture of NS and regular to adjust the LSD's effectiveness. But you should use at least one quart of regular which contains the friction modifier.
2004 GT3
Old 10-13-2005, 03:36 PM
Re-edit:
Tyson,
My car is an '87 with an LSD, for Redline, I should NOT get the NS type right?
thanks
Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 10-13-2005, 03:49 PM
