rickeolis's Avatar
Porsche Crest Steering wheel removal?
I'm selling mine as I'm parting out my whole car, but I can't see any method of removing it.
1969'T' style, thanks-
-Rickeolis-
1986 Corvette
Old 03-21-2004, 05:12 PM
GrindingGears's Avatar
Remove horn pad.
Horn wire while be attach the back of horn pad,
Remove 27mm nut and washer.
Pull it off.
83 SC (gone) // 72 T (gone)
Old 03-21-2004, 05:20 PM
rickeolis's Avatar
Porsche Crest
I wish it were that simple. I removed the horn pad already and there is no nut under it.
I need to get a pic to show what I'm seeing. Thanks-
-Rickeolis-
1986 Corvette
Old 03-21-2004, 05:37 PM
Slippery Slope Victim
NY65912's Avatar
Look down in the empty space, in the neck of the steering wheel, there's got to be a nut holding the wheel to the steering shaft. If you put a 27mm socket on the end of a 10"+ extension I bet you can just insert it down into the wheel and land on the nut.
MikeČ
1985 M491
Old 03-21-2004, 05:49 PM
rickeolis's Avatar
Porsche Crest
Just went out and got this:
-Rickeolis-
1986 Corvette
Old 03-21-2004, 05:51 PM
NY65912's Avatar
Are those three allen head socket screws into the hub? If so they obviously must come out in order to acess the nut.
Good Luck........Mike
MikeČ
1985 M491
Old 03-21-2004, 05:53 PM
rickeolis's Avatar
Porsche Crest
No, they are recepticles for bolts from the other side out, nothing I can do here...
thanks-
-Rickeolis-
1986 Corvette
Old 03-21-2004, 05:56 PM
NY65912's Avatar
Wait a minute, is that a wing type wing horn button. If so you have to twist it off the steering wheel hub and then you have a clear shot at the nut.
Mike
MikeČ
1985 M491
i have no idea...sorry.
Old 03-21-2004, 05:57 PM
Send a message via AIM to fintstone
Rick
Looks to me like you screwed up and pulled the pad off the horn button. If you did not damage it, you can glue it back on. Press the rim of the horn button down on both sides at the same time and rotate counterclockwise. It should release.
Stoney
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 03-21-2004, 10:17 PM
rickeolis's Avatar
Porsche Crest
Stoney comes through again!! Thanks so much!
So rotate about 90 degrees, or does it unspin like a nut?
Yeah, the pad came off easily, so I'll glue it back again...
-Rickeolis-
1986 Corvette
Old 03-22-2004, 07:58 AM
Ayo Irpin, Ukraine!
70SATMan's Avatar
Rick, What are you doing to my wheel. DON"T reglue it. Just send it to me as it is and I'll take care of it.
Is everything else coming out OK?
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 03-22-2004, 08:24 AM
rickeolis's Avatar
Porsche Crest
Sounds good! As you see in the picture, it simply comes out as a X-shaped pad quite easily Michael, don't fret!
Everything is cool so far.
TTYL-
-Rick-
-Rickeolis-
1986 Corvette
Old 03-22-2004, 09:05 AM
Ayo Irpin, Ukraine!
70SATMan's Avatar
Just joshin ya No worries. I got much bigger fish in the pan. Hey email me about the details on the pedal cluster. What kind of shape is the carpet set in?
And by the way. Get back to work pullin my parts!
Old 03-22-2004, 01:32 PM
rickeolis's Avatar
Porsche Crest
I'm on it! All I lack now is the steering wheel and the long rods in the tranny linkage. I have the shifter itself out, TTYL-
-Rickeolis-
1986 Corvette
Old 03-22-2004, 02:11 PM
rickeolis's Avatar
Porsche Crest
Stoney and Michael- Got it!
Simple twist of the horn bracket like Stoney said, and viola!
Thanks much-
Michael, all I lack now for your order is the shifting tube back to the tranny, I'll e-mail you on this issue-
-Rick-
-Rickeolis-
1986 Corvette
Old 03-23-2004, 07:27 AM
'70 GS
'73 911T
'87 325IC
"Let go of whatever holds you back"
Old 10-16-2005, 08:40 PM
