-   -   Problem removing cruise control - vacuum lines (http://forums.pelicanparts.com/porsche-911-technical-forum/246527-problem-removing-cruise-control-vacuum-lines.html)
PcarPhil 10-17-2005 12:59 PM
Yesterday I was pulling off some weight off my '80 911SC which included removing the cruise control system from the engine compartment.
When I was removing the cruise control soleniod it had two vacuum lines attached to it, one small and one large. I saw where the small vacuum line attached to the engine but when I was pulling out the cruise solenoid the large vacuum line came out with the solenoid like it wasn't connected to anything on the engine side. Now I'm paranoid that I have a sizeable vacuum leak somewhere on the backside (frontside?) of the engine.
Does anyone know where the other end of the large vacuum line connects to my 3.0 engine? I'm thinking I might need to get a mirror and look around to see if there is a hole that needs to be plugged.
I'm thinking I would hear a vacuum leak of that size but I want to be sure that I haven't left anything unplugged.
Thanks for the help,
-Scott
wilke3169 10-17-2005 01:02 PM
It doesn't hook to anything. It is a vent.
Your lucky day...
PcarPhil 10-17-2005 01:03 PM
YES!!!!!!
Thanks Kevin!
