Can't be that simple.
I'm replacing the carpet in my 911. The rear seats appear to be held against the outsides with a slotted screw/bolt and slip onto a pin in the middle.
I can't get either side to move with a pretty big screwdriver--do I just need to lay into it, or is there some trick? |
I had to take out those seat backs to install my bolt-in rollbar. If I recall the outside screws/bolts were not cooperative as you have found. I think used a big screw driver with a square shaft and an adjustable wrench on the shaft to turn it.
Good luck Andrew |
Yea, it's that simple.
But I had to file the end off of a wide chisel to make a super-screwdriver and then put vice grips on it to get enough torque to get mine loose. Good luck. |
| All times are GMT -8. The time now is 03:08 PM. |
