Kirk911SC's Avatar
No start after partial drop
So I took my car into my mechanic yesterday (factory trained, PCA recommended) to repair some bad oil leaks coming from the rear of the engine.
They did a partial drop on the engine, replaced the oil pressure switch, and the thermostat gasket I believe. Apparently there was lots of oil in that area. Engine was steam cleaned, and reinstalled.
They then ran the car on the hoist for 10-15 minutes with the muffler (M&K) disconnected (was impeding the partial lowering) to heat the oil up and look for more leakage. The engine was again lowered partially to check for leaks. None found. Perfect, or so I thought.............
Went to pick up the car yesterday. Engine had not been run since its second reinstall. I get in, turn the key, nothing....hmmm.......assistant mech forgot to reconnect wiring harness. No problem..........start car, fires up perfectly..........10 seconds later sputters, chugs, won't take any throttle without backfiring, dies. Repeat, same sequence of events.
Hmm.......mechanics look at each other with a "Oh S**t" expression. They try and figure it out for about 30 minutes while I wait.........no luck. Come back tomorrow was the final answer.
Any ideas???
Kirk
- '00 Dodge Viper GTS - Steel Grey - Yep...a domestic.
- '87 930 - Guards Red - Sold
- '82 911SC - Grand Prix White - Gone
- '78 928 - Silver - Long gone
- '04 Subaru WRX wagon - Sold
Old 10-19-2005, 06:47 AM
Rick Lee's Avatar
Could be the old coincidental fuel pump failure. I'd check that, fuel filter and accumulator. These things can fail anytime.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 10-19-2005, 08:16 AM
Kirk911SC's Avatar
The fuel pump whines away as usual. Filter was changed about 3-4 months ago. The accumulator.......might be original. Never had any hot start issues.
Kirk
Old 10-19-2005, 08:29 AM
IROC's Avatar
I would suspect something that was a function of the engine drop and not a coincidental failed component. Maybe a kinked or pinched fuel line? This might allow the engine to start and run briefly only to stall as the fuel flow requirements increase.
Just an idea. Sounds fuel related, though...
Good luck.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 10-19-2005, 08:57 AM
ianc's Avatar
Any ideas???
Yeah, let them fix it. They busted it.
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 10-19-2005, 09:15 AM
Kirk911SC's Avatar
Verdict is in, car is running.
Apparently there is a 12 pin wiring plug at the back of the engine that was not fully seated.
Runs fine now.
Kirk
Old 10-19-2005, 10:00 AM
Darn I had the answer. Glad it is fixed but that happened to me on my '81 once. After hours of struggling to find the answer, I took the connector off and reconnected it and all was back in order.
Kevin
'79 Coupe
Old 10-19-2005, 10:33 AM
